01-02-2007, 10:39 PM | #1 |
Pebble Pounder Join Date: Jan 2007 Location: So.Cal
| My shopping list I'm missing something?
Well thanks to kerosinek he help me chose everything i could need so i can start on all this stuff. and here is the List. are we missing something ? Here is the list. 1. XTRA Seismic Car ESC F/B/R 18-27 Turn http://www.hobbypeople.net/gallery/158184.asp 2. Tamiya TLT-1 Rockbuster 1/18 Monster Truck Kit http://www.hobbypeople.net/gallery/312774.asp 3.Trinity Chameleon 2 Pro 19T Motor http://www.hobbypeople.net/gallery/839106.asp 4.Cirrus CS704MG 13kg/cm Hi Torque Servo http://www.hobbypeople.net/gallery/440704.asp 5. Pro Peak 300 7.2V 3A DC Peak Charger 6. Deans Ultra Plugs Male (2) 7. Deans Ultra Plug Female Connecters (2) 8. Associated AE Transmitter 2ch 27mhz AM#1 9. Traxxas Receiver w/BEC 10. Traxxas Crystal Set 27.145, #4 Yellow 11. Global 6 Cell 3600mAh Ni-Mh Stick Pack Wired Sanyo Well with all that i would be ready to rock ? or i need anything else ? BTW: the total for that is about 330 bucks. Or i better get a clod buster ? |
01-02-2007, 10:41 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: Oak Lawn, Illinois
why a 18t motor in a rock crawler stock tlt isnt that great and the trans sucks |
01-02-2007, 10:50 PM | #3 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
Are you planning on running it stock? I would also go with a 45T-55T lathe motor. You'll get much better run time. Depends on if you want a basher or a crawler. That ESC says 18-36 turn motor so you would have to get a different ESC to run a lathe motor. I run a Novak XRS and it's about the same price as the XTRA. Same BEC which really isn't much. But will be fine for 1 servo. You'll more BEC's if you want to run 4WS.
01-02-2007, 10:53 PM | #4 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
get a Moped ESC ,it's $40 and a Axiom55T lathe for $25 it's cheaper .
01-02-2007, 10:59 PM | #5 |
Well the main problem here is that I'm on vacations in L.A and i got to return to Mexico this Sunday so i don't have any time to order online. I need to get everything on a store near my location. That also have everything in stock so i can pickup all i would need. If anyone can provide me some links to stores near L.A to check out what i can get. |
01-02-2007, 11:08 PM | #6 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
Tires, can't forget better tires. The stock ones will work for a bit, but you will want to upgrade at some point, just keep them in mind if you want to get stuff now. If they have a smaller pinion that will work with the TLT spur I would recommend looking into that as well, they are reasonably cheap. |
