Sidewinder 3, What wire to cut after BEC install Hi, So I know I need to cut the red wire on an ESC with red black and white wire when installing a BEC... My new sidewinder has brown, red and Orange. Is it still the red wire? Thanks!!!!! |
Re: Sidewinder 3, What wire to cut after BEC install Most likely it's the middle wire and you don't actually have to cut it. You can get the pin to release from the servo connector and then tape it up to the rest of the wires allowing you to put it back to stock without any modification in the future. All you need is a tiny tip. I usually use a pin or the point of a thin blade Xacto. |
Re: Sidewinder 3, What wire to cut after BEC install Yes, red is power, brown is ground, and orange is signal. Like Chup said, don't cut just pull out of the connector. |
Re: Sidewinder 3, What wire to cut after BEC install Thanks!!!!!! |
Re: Sidewinder 3, What wire to cut after BEC install And there's another reason not to cut it. If you ever want to do any esc programming with a Castle Link, you'll need to temporarily restore the red wire in the connector. |
Re: Sidewinder 3, What wire to cut after BEC install Nice thank you all a ton. I got it out safely, working on re assembly now |
Re: Sidewinder 3, What wire to cut after BEC install I prefer a 3" extension, and remove the red altogether . I don't worry about the esc powering my receiver , as I run at 7.4v using a Holmes rx http://uploads.tapatalk-cdn.com/2016...b0134797ac.jpg Hang up and Drive |
Re: Sidewinder 3, What wire to cut after BEC install I've always ran those Holmes bypass harnesses, so easy. |
Re: Sidewinder 3, What wire to cut after BEC install The guy in my lokal LHS told me just to lock at the wire colors like you are color blind. Darkest is ground, brightest is the impuls, the other is power.:mrgreen: |
Re: Sidewinder 3, What wire to cut after BEC install Quote:
