Newbie question Hi All , new to rc crawling and posting questions , Im from Perth Australia and have purchased an axial rr10 bomber kit and have completed the build .The builders kit is all stock .I am currently running the following motor- castle 1410-3800kv four pole brushless motor and castle sidewinder sct esc ( these were a boxed package ) . Transmitter is a Futaba 3PV . The motor seems to spool up faster in reverse than forward . The direction is correct and I have checked the transmitter setting and sub settings and all seem correct , have calibrated the transmitter to the esc several time and still no change. What am I missing . Any help much appreciated |
Re: Newbie question If you have the CastleLink, you can go into the software and change the motor direction. You’ll need to reverse the ch2 direction afterwards. This option is a must if you were to be running a sensored ESC, the sidewinder is not. Or just unplug 2 of the motor wires from the ESC and swap them around then plug back in. All else should remain the same. This option works for sensorless ESCs. |
Re: Newbie question ok so unplugging two of the black motor wires and swapping will not cause any motor damege etc |
Re: Newbie question Quote:
