10-22-2007, 07:09 PM | #1 |
Rock Crawler Join Date: Sep 2004 Location: South Orange County
| comp rig gear ratio
hey guys i have a comp ready sw2 tlt 55turn lathe with hard brushes locked and loaded pede tranny locked axles the usual im going to my first comp and i was wondering what gear setup i should run. http://www.socalrcrc.com/home/index.php 87tooth 14tooth pinion? im running a 84 tooth spur and 12 tooth pinion right now |
10-23-2007, 12:03 PM | #2 |
The proper ratio is really more dependent on preference. The best all-around ratio is probably the 14/87 but you should be getting close to the same ratio with 12/84. I would maybe get yourself an 87T spur and then buy a few different pinions and experiment. What I do is run a rather low ratio with a higher voltage battery so I have some extra wheelspeed should I need it.
10-23-2007, 05:12 PM | #3 |
i have an 87 tooth sur allready im gunna get a 14tooth pinion and try it out.
