nimh vs. lipo run time right now im running a 3600 7.2v 6 cell battery and im getting huge run times outa it like 1 and 1/2 hours what size lipo bat would i need to compare to this (run time and power) because i want to get one because they just seem better plus weight the only thing is they are so freekin expensiv so if i could get some prices on the batteris youtell me about that would be great thanks |
I have a Common Sense 2s 10c 2000mah Lipo and I get around or more run time that that. I have a real close setup as you. |
what kind of motor r u running, and gearing to be getting 1 1/2 hour run time? |
Well, to match the run time you will need a 3600 mah 2 cell. A mah is a mah, no matter how small. |
do lipos have normal connectors like tamya or do i have to do something special and can i use my rooster crawler esc and where is a place that has lipos the cheapest |
stick with the ni mh if your after runtime. a ni mh you can run dead. a lipo you can only use about 1/3 or youll have your self a nice puffy paper weight :D most of the lipos i buy have no connector, the last batch i bought came with deans compatible connectors though, nice cause thats whay ive used for the last decade lol |
sorry i had voltage on my brain:roll::lol: |
maybe i will just go saddle pack is there a saddle pack that will give simmilar run time cuz alll i can find are 1500 and stuff, and can you please send me links, and links to where i can get the mounting plates for the saddle pack |
Nope, 1500 is about the biggest that will fit on the axle. |
how much run time will i get witht the 8 cell 1500 |
By my calculations 37minutes. |
You can get it all at TheCrawlerStore. |
go herehttp://www.cheapbatterypacks.com/main.asp?sid=920216 for all your battery needs. they make custom packs also. |
What do you guys think about this saddle pack, will it fit and work with the Rooster Crawler esc? http://www.maxamps.com/proddetail.ph...-Saddle&cat=13 |
