2 plates on 2 to go the roof is 12mm thick in the back and 3 mm in the front http://i247.photobucket.com/albums/g...r/IMG_1473.jpg |
Looking good. I am sure those curves are keeping it challenging. |
yeap curves are a b**ch |
added some primer today to c where i missed time to add some filler ,then i will prime and cut the door jams in http://i247.photobucket.com/albums/g...r/IMG_1496.jpg http://i247.photobucket.com/albums/g...r/IMG_1497.jpg |
Coming right along your styrene work is always great. |
its starting to look like a truck |
Great work joe, looks sweeter than a virgin dipped in chocolate. :lmao: |
yummmy chocolate |
i have to use same chassis as the r-mack because the wheel base is the same http://i247.photobucket.com/albums/g...r/IMG_1498.jpg |
wow |
You've got some mad skills Joe!! That is art in styrene. I should have taken more pictures when I was in Bogota last time. Down there you'll see 50's and early 60's Macks, GMCs, Whites, etc., all kinds of old trucks that are still on the road hauling freight and making money every day. Many of them have obviously been very well taken care of over the years too... |
hey thnx man!! |
i had to make few changes but i think i got it now ive added an inner fire wall.this will have a lifted hood on it http://i247.photobucket.com/albums/g...r/IMG_1501.jpg |
Very nice,Joe.Work of art."thumbsup""thumbsup""thumbsup" Are you going to bring the cab closer to the ground?The 1:1's i have seen and similar trucks from that era are relatively low compared to other,more modern,trucks. |
you are correct about them be alittle lower.what it is ,is that its not the cab thts lowered its the suspension thats to high.i noticed that the tire are above the frame rails and tha cab still sits on top the frame rails |
the fender will be a 2 part build just like the 1:1 truck there is an inner fender which is more then half the fender then there is an outer which is where the big curve is this will also make my build easier tell ya watching a 1:1 being built make it a whole lot easier http://i247.photobucket.com/albums/g...r/IMG_1504.jpg http://i247.photobucket.com/albums/g...r/IMG_1505.jpg |
Suscribed and awaiting more progress pics."thumbsup" |
