Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: painting styrene
Old 05-05-2012, 08:36 PM   #1
Default painting styrene
I have painted lexan so know how that goes but what paints stick to styrene? I have heard people use krylon fusion, model brush on paint. I work at a body shop so i could use a PO primer then car paint and clear. Does the plastic need a mechanical scratch like a grey scotch brite or just a chemical one from the primer? Please help the body is a hilux.
camino ty is offline   Reply With Quote
Old 05-06-2012, 06:09 AM   #2
58_Willys's Avatar
Default Re: painting styrene
Styrene is just like plastic model bodies, so after a good primer, anything goes except the paints for lexan/polycarbonite. I have had good results with duplicolor sandable primer, and the same for auto body colors in rattle cans, and then clear coats. Any of the model paints should be no problem, Testors, Model Master, Tamiya...you should always primer the styrene first, no matter what paint you choose to use. You Tube has some good how-to's, just search for, painting model car bodies. Good luck.
58_Willys is offline   Reply With Quote
Old 05-06-2012, 06:13 AM   #3
Make sure to clean the body thoroughly before priming.
The release agent from the mold can be quite hard to remove sometimes.
4wd4ws is offline   Reply With Quote
Old 05-07-2012, 10:54 AM   #4
58_Willys's Avatar
I agree with 4wd4ws...Castrol Super Clean might be good for this, as it won't harm the body. Just rinse really well before painting, it tends to hide in the recesses. An old toothe brush should work good here. And keep it off your hands, the slimmy feeling you have when cleaning with this stuff is your skin.
painting styrene - Similar Threads
Styrene-Where?? ridepate Paint and Body 19 12-23-2011 02:22 PM
Styrene TXJeeper1 Scale Accessories 7 08-11-2010 07:45 AM
Styrene How To martinez34 Paint and Body 14 06-27-2010 09:03 PM
need help with painting styrene minor_threat Paint and Body 5 01-29-2009 01:17 PM
Painting Basics - Painting Tips and Tricks stampedeproject Paint and Body 0 03-09-2008 10:39 PM
