Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Body work
Old 03-03-2015, 12:11 PM   #1
Default Body work
I have a Tamiya hulix and I'm looking for a good product to fill for the holes. Any suggestions on what to use. First time working on a hard body. Thanks for your help.
Mr.lee is offline   Reply With Quote
Old 03-03-2015, 06:16 PM   #2
Default Re: Body work
All the info you need on body mods/repair and hole filling... ☆ The Chop Shop What Glue to Use For Body Work/Repairing Cracks in Plastic and Why ☆
lonleycreeper is offline   Reply With Quote
Old 03-03-2015, 06:24 PM   #3
I just use a tube of auto body spot putty, the red stuff ....
bob1961 is offline   Reply With Quote
Old 03-03-2015, 07:31 PM   #4
Most putty, bonda or fillers will shrink and crack. Best solution is to back the holes with styrene if the are small or cut a filler piece for larger holes, then make a slurry/paste from styrene bits and fill the gaps with that. Bondene, weld-on 3, MEK, tanex, etc all work for solvent welding styrene which is what you will be doing with the above methods.
hotwheels000 is offline   Reply With Quote
Body work - Similar Threads
body work THEmicroRR RC4WD Trail Finder 2 5 08-20-2012 05:55 PM
A little body work help please hende Paint and Body 4 09-19-2010 07:25 PM
Anyone do Body Work? Shaun Chit Chat 8 07-08-2008 06:45 PM
a little body work! madhatter Paint and Body 15 02-03-2007 12:13 AM
