Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: SCX 10 Comanche Body
Old 07-11-2016, 01:33 PM   #1
Default SCX 10 Comanche Body
I finally got my comanche body done ,. I had done a scale honcho body that I went all out on ,.however with all the additional items interior roof rack etc ,..as awesome as it looked ,..it was a little top heavy & prone to rolling ,..so this time I opted to go minimal with no interior , I wanted to use window cling to tint the windows ,but it didnt work well so I went with platidip smoke spray bomb ,..seems ok & can be peeled off if you change your mind ,.I did all the lower in black ,but I didnt like the glossy look so I went over the same area on the outside of the body with black plasti dip ,..I dont know how well it wear but it looks ok now , & platsidip is easy to remove ,redo , or repair , I also ended off masking the window trims & sprayed them with black plastidip too ,I hate doing window trims ...& to finish off I installed a cheap turn signal brake light kit from ebay & just scratched off the paint behind the decals & hot glues the leds behind them ,..
BL4Z3 is offline   Reply With Quote
Old 07-12-2016, 08:54 PM   #2
Looks nice!
sawhead is offline   Reply With Quote
Old 07-13-2016, 07:08 AM   #3
Moderator
JatoTheRipper's Avatar
Default Re: SCX 10 Comanche Body
Nicely done. Your photos are great.
SCX 10 Comanche Body - Similar Threads
Scx-10 Jeep Comanche Trail Run truckus Videos! 3 04-23-2014 04:39 PM
Rapid Rhino - SCX-10 Comanche Kobier Axial SCX-10 4 07-11-2013 05:36 PM
