09-23-2019, 07:30 AM | #1 |
Rock Stacker Join Date: Aug 2019 Location: Youngstown, OH
| Painting a VW baja
I have a proline baja body I want to paint. I know I have to paint from the bottom, and use paint made for the lexan. What I dont know is what paint to use for an airbrush?
09-23-2019, 07:35 AM | #2 |
| Painting a VW baja
ProLine has a new line of paints, similar to Faskolor by Parma. Does have a learning curve as it’s WB I did this for the wife , first time with ProLine paint, worked pretty good after some reduction and pressure adjustments. Hang up and Drive |
09-23-2019, 07:39 AM | #3 |
| Re: Painting a VW baja
Thanks, would an acrylic paint marker work for fine line work? you know, like window trim etc
09-23-2019, 08:26 AM | #4 |
| Re: Painting a VW baja How well is the Proline paint holding up for you?
09-23-2019, 09:17 AM | #5 |
I’m impressed, I was able to shoot at lower psi vs Parma or Auto Air. Seems to stick well, nothing chipping or peeling. I used Black, Fuchsia, Hot Pink, White, Black, semi matte clear outside. All reduced a bit differently, common with most WB paints Hang up and Drive |
09-23-2019, 01:52 PM | #6 |
I like the Commanche Mike. Turned out real nice!
09-23-2019, 03:33 PM | #7 |
| Re: Painting a VW baja |
09-23-2019, 03:34 PM | #8 |
09-23-2019, 05:57 PM | #9 |
Painting a VW baja - Similar Threads | ||||
painting new baja bug body? | lildjloop | Axial AX-10 Scorpion | 6 | 04-03-2009 04:09 PM |
Painting Basics - Painting Tips and Tricks | stampedeproject | Paint and Body | 0 | 03-09-2008 10:39 PM |
