05-30-2011, 10:25 AM | #1 |
| caster
I'd like to change the caster without clocking the axle, are there any products out there to this end?
05-30-2011, 10:40 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
Not for a bully because the "c" is made to the axle tube. Axial can do it because the "c" slides onto the axles tube so it can be rotated.
05-30-2011, 10:50 AM | #3 |
0 0 Join Date: Jul 2006 Location: FT. Thomas
you can do what I did if you got a little spare time. |
05-30-2011, 10:57 AM | #4 |
| bumber
I rotated the axle back about 10 degrees...the steering is MUCH better but the motor is way to low. I'm going to switch it back and dig, dig, dig |
05-30-2011, 10:58 AM | #5 |
| Cool |
05-30-2011, 11:01 AM | #6 |
| Here's the thread. Don't have an official writeup. Wasn't that bad though. Some simple measuring and a lot of grinding. The rebuild |
05-30-2011, 11:29 AM | #7 | |
| nice
That's straight up genius...you should get a bunch of these cnc'd and sell 'em, there's a small fortune here. Quote:
05-30-2011, 11:34 AM | #8 |
IDE say krakker was the first. I just took his idea and made it work with mostly stock parts. If I owned a lathe and a small mill IDE definitely offer this as a service. It would be so easy with the right tools.
05-30-2011, 11:53 AM | #9 |
| indeed
If you have access to a CAD, you could make a completely new aftermarket kit. We have a great machine shop here in Albuquerque that would happily do this sort of work and still give you a good resale margin. clarkmachining.com if you don't have CAD, I'm sure they can reverse engineer it for you. |
05-30-2011, 12:02 PM | #10 |
It would be nice to bring more options to the bully line but I'm not the person for that. I don't have cad nor the funds to invest in getting a kit going. I've never ventured downn that road but I'm sure it's more than I can afford. Besides if I were to go that route I think krakker's idea would be more successful. Just a matter of cost and demand which I don't think there is enough of.
05-30-2011, 02:01 PM | #11 |
romulus22....nice job. I was going to clock my axle tubes, but the I would have had to redo the steering servo mount. Were these Axial XR-10 C-hubs?? |
05-30-2011, 02:11 PM | #12 |
Those are AX10's.
05-30-2011, 02:13 PM | #13 |
05-30-2011, 02:19 PM | #14 |
Just so you know if you wanted to run XR10's you'd have to run the knuckles too, then your into bearing issues with the bully axles.
05-30-2011, 02:54 PM | #15 |
