01-04-2010, 06:44 AM | #1 |
RCC Addict Join Date: Jul 2008 Location: Sin City
| Culetto's 2010 Bully ''Candy''
I guess i need to explain this name a bit ..... The biggest problem i have had with the bully's since i got them more than a year ago was also what made them great, BEEF! I'm still amazed at how much i have beaten on these axles and they always are ready for more. This BEEF also raises some other problems that any other bully owner will already know, clearance around the big ass gearboxes. Shocks hit them, links hit them, servos hit them, tires hit them, chassis hit them, etc etc. So when i started planning my 2010 rig i was already considering this as an issue since i knew i was going to a fully sprung rig this season (the torsion front JP Havoc chassis doesn't have shocks so it wasn't really an issue last year). I planned and plotted a LONG time, then one day at work i was talking to a lady at the bar who is ....... an entertainer. She happened to be very excited cause she invented a new move on the ''pole'' ( this is sounding bad even trying to not sound bad) that she described as ''going into a forward handstand, gripping the pole with her thighs and using her legs outstretched to cantilever herself up to grab the pole (OK stop laughing now!). ANYWAY, i had the flashing then and since the Traxxas GTR's are my favorite shocks it all came together surprisingly easy so i have a girl named rig which is OK with me since ''stripper candy'' is a local term for a big wad of cash. Candylevers? LOL, ok ill get to the pics. The chassis is an old Havoc i cut the front off of and flipped around. Ill be running a new Prototype Hellstrom before this hits the rocks but the rear of the Havoc is identical to the hellstrom so i could cut/drill this one up and then just transfer everything once the design phase is done without unnecessary changes to the prototype. Traxxas makes some of the best shocks in the business, ive even seen a couple local racers using these on their 1/8 buggys just because they are so smooth and leak free. The fit between the chassis plates is just perfect. I used Traxxas Revo Long Travel 2 rockers eventually (i tried them all, trust me). They pivot on the stock rocker posts with the stock bearings. The bottom of the rocker is ''6.1m coarse'' threaded so it took some hunting to find nuts that would fit them. I just drilled the lower inside hole out to fit and dropped them in. Again, EASY. I'm not nearly as cool as some people who can have their parts custom made, LOL. These front actuator links for the cantilevers are actually an old Kamikaze steering link i cut in the middle of the raised part and used both halves. The links need to angle in a bit like this so they clear the servo/gearbox and also so they line up better with the revo ends. Some of these turned out blurry but ill change them out when i put the final chassis on it. Tires turned all the way, they now hit the lower links before anything else, the actuator link isn't even close, HURRAY! This is max flex, ill have a hole in the body for the rockers to push through, i thought about moving stuff around but the body mod will look cool. This thing has a lot of articulation (like a good stripper should). Notice that even at full lock and full articulation the tire is only barely pushing into the lower link. The GTR shocks really make this a tuner setup which i like. The oil/spring/preload adjustments are all easily made and really allow me to track what works and doesn't. I also switched to a cast front Bully so i could better tune the weight balance. There is still room in my chassis for the electronics and the battery will still fit into the belly like i like it. The setup is NOT heavy, its actually surprisingly light. Just to make sure i can still keep as much weight as possible down on the rig 90% of the hardware will be titanium. I raided RC4WD's sale a few weeks back and bought 50-60 of every size they had in Ti screws. The upper links are 4mm Lunsford Punishers. I might switch out all the revo ends to their aluminum racing versions also but im not sure yet, Traxxas also has a lightweight rocker pivot that i have ordered and Hard Core Racing makes Titanium Revo rockers in a variety of sizes i will have to order also. If you want to build the same setup i have all the JP Customs, Traxxas and RC4WD part numbers. Flame On |
01-04-2010, 07:00 AM | #2 |
That is looking good man! I've got a cantilever setup coming for my Super Bully!
01-04-2010, 07:28 AM | #3 |
Rock Stacker Join Date: Nov 2009 Location: Europe
wow - like the idea, looking forwards to the video :-P
01-04-2010, 07:54 AM | #4 |
Rock Stacker Join Date: Nov 2008 Location: Under Your Ma Ma's Bed
This is the best build I have come across yet. I want to see some video of it on the rocks. |
01-04-2010, 08:44 AM | #5 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I love the story and the moment of inspiration behind the build... it's good to have things that inspire you in life this is a very cool build I'm pumped to see the coming progress nice job bud. |
01-04-2010, 10:26 AM | #6 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Can we get some pics or video of the stripper doing her move on the pole. I think you got a great Idea here, it makes me want to try it. keep us posted. |
01-04-2010, 11:02 AM | #7 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
01-04-2010, 11:19 AM | #8 |
RCC Addict Join Date: Apr 2009 Location: Anderson
I really like the "out of the box" thinking on this one! That is a great way to move the shocks out of the way and allow much greater turning. I might have to give something like this a try! -Jason |
01-04-2010, 12:14 PM | #9 | |
Thanks for the comments all. | |
01-04-2010, 04:46 PM | #10 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
nice mods Chris,,,looks good,,do you get any inner chassis twist from having the shocks inboard,,ie: pressure from the shocks pushing the side plates
01-04-2010, 05:52 PM | #11 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Man that is slicker than dog snot. |
01-04-2010, 06:47 PM | #12 |
Rock Crawler Join Date: Aug 2007 Location: Orlando
Clever setup, can't wait to see some runnng pics..maybe a vid? |
01-04-2010, 06:55 PM | #13 |
Rock Crawler Join Date: Sep 2008 Location: Utah
Awesome job! Im curious to see how it performs!
01-04-2010, 08:14 PM | #14 |
Pebble Pounder Join Date: Jul 2009 Location: Splendora, Tx
great set up, that much steering on bully's is sick. Great fab job on the whole set up. |
01-05-2010, 01:38 AM | #15 |
Dog snawt! hahaha Thanks for the comments guys Yes it does apply some different pressure because of the angle change of the articulation link and the rocker itself moving. Its not really more flex than the Havoc torsion setup just a bit more leverage from the rocker. Once i put the cross braces in it firmed right up. |
01-05-2010, 01:55 AM | #16 |
Quarry Creeper Join Date: Jan 2009 Location: North Wales, UK.
This build is superb! Great idea with the 'Candylevers'! Now I just gotta convince wifey that a Stripper bar is the place to go for inspiration!!! |
01-05-2010, 02:52 AM | #17 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hi, "Candylevers" are very, very, very cool Greetings Frank |
01-05-2010, 04:15 AM | #18 |
I like it.... Has me thinking of my 2010 Build now.. I've got an idea now, from your build. That I'll use on my New HaVoc Build.. |
01-05-2010, 04:31 AM | #19 |
RCC Addict Join Date: Feb 2008 Location: Nevada
I was thinking of a good chassis to get....i might wait on that one and see how this candy works out. you might just have invented a new chassis here for a vendor to come up with. on the 6th pic looks like it might try and lift the body up, which i'm sure if thats all you have to worry about...... looks good, & looks like you have alot of people staying tuned to this thread, nice build |
01-05-2010, 10:52 AM | #20 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Such a cool idea. It will be nice to see how it works for you. Looks like I will have to give those shock a try, with the way you talk about them. |
