Bully motor Thread Ok Guys lets get some of the Bully tech going. What motors are you running? perhaps we can keep it in this format: Brand: Integy Turn: 35 Front and Rear Pinion front:12 Pinion Rear:12 Battery:3S 1350 Mah Comments: The motors have more jam then most would need. Or that most would think they need. This thing will keep up with the locals trail trucks. I can jump it and pull wheelies in both reverse and forward. The Crawling ability is definatly great with this motor combo i have the EXP on the DX3R set to lower the throttle curve near the deadband so i have more crawling control Clod stall is a little on the high side for me. I chalk that up to the fact that the front motor has less then 2" of wire between it and the Punk dig. The rear has about 8" of wire. Wire is 12 gauge. Batt time on the 1300Mah isn't great i get about 15-20 min per bat. All in all i'm very pleased. here is a vid from my living room. No Steering servo! http://img.photobucket.com/albums/v2...h_DSCF5052.jpg I know there is a thread with a few comments on this but lets leave this motor and pinion tech ONLY. |
my current Favorite motor is the Banzai motors..they are fully dipped in epoxy and they seem to last a lot longer then other hand-wounds I have tried.8) Banzai 35T 11T/Front 10T/Rear I run them on 3s lipos and 4s lipos8) this will be my next combo.. Banzai 45T 11T/Front 10T/Rear (on 4s lipos) |
Tekin 45t Stock Pinions on both I think it's 11 |
Turn: 45t Novaks front and rear Pinion front: 12 Pinion Rear: 12 Battery: 2200 2s lipo would like to try a different pinion for the rear! I want the front to grab more. |
Integy 45T's .01uf capacitors front pinion 13T stock rear pinion 12T Battery 3s lipo 2750mah 25C Would like to change F or R for a 11T or 13T |
Brand: Integy V11 Turn: 35 Pinion front: 11 Pinion Rear: 10 Battery: 3s 1300mah 25c |
Brand: jp customs warriors Turn: 45R Pinion front: 12 Pinion Rear: 11 Battery: 3s 1350mah 25c |
Tekin 45T 12T front and rear hyperion 1100 35c 3s fusion 1300 25c 3s |
Novak 55t 12t/13t 12t rear 3S Lipo, 1050mAh, 30C This combo gives enough wheelspeed while maintaining lots of torque. The bigger pinion up front helps a lot against clod stall in the rear, in some situations too much as the front now stalls quite easily. I'm not quite sure which setup I like better. |
motors motors 45t epics front pinion 12 tooth rear pinion 11 tooth 3s lipo |
Brand: HH/ have a set of fantom blitz motors that I have not yet tried out Turn: 35T Pinion front: 12 Pinion Rear: 12 Battery: cheapbatterypacks.com 3s 850MAH 45c Comments: Fairly happy with the holmes hobbie motors but I am sure there are better ones out there. Can't wait to try out the blitz motors, I have heard good things about them. |
brand:integy motor:45t pinon: stock front and rear 12 battery: turnigy 2200 3s comments: with this battery and motor combo it seems good. when i need the wheelspeed its there. |
Brand: Fantom Blitz Turn:35T Pinion front: Currently 13T but changing to 12T Pinion Rear: Currently 12T but changing to 11T Battery: Max Amps 2200 30C 3S Comments: The Fantom Biltz motors are great. I am very happy with them. I just hope they hold up as well as some of the other brands I have used. |
Brand: Holmes 454 pullers Pinion front: 10t Pinion Rear: 10t Battery: Rhino 1050mah 3S 40C comments: throttle EPA had to be limited down to 60% to limit WHEELSPEED! |
Brand: Team Brood 45t handwounds Pinion front: 12t Pinion rear: 11t Battery: Turnigy 1000mah 4s Comments: Throttle is at 150%, no limiting wheel speed for me. 4S FTW! |
Brand:Tekin Turn: 45s Pinion front:13 Pinion Rear:12 Battery: 1800 2cell Im able to get around 20 minutes runtime and the "clod stall" is not all that bad. Also thinking about going to Holmes or Blitzs |
Brand: Castle Creations/Neu Turn: 2650KV Brushless Inrunners Pinion front: Stock Pinion Rear: Stock Battery: 6s 50c 1500mah Comments: Just kidding, i only run 55t on 3s, nothing fancy. I did bolt up 2 2650 monster motors on the bully's once just to take some funny pictures and freak everyone out but i never ran them, wouldnt be able to get the links back on the motor side, lol. |
Brand: Cobalt 27t stock motors Pinion front: Stock Pinion Rear: Stock Battery: 2s 1300mah Comments: I ain't run it all that much but couldn't C running higher turn motors when I had these already. Seems to have plenty of wheel speed and torque. We'll C |
brand:integy motor:55t lathes,,handwound to 45t's pinon: stock front and rear 12 battery: 2S & 3S ESC: Rooster Crawler BEC: CC BEC PRO @ 6VDC |
i got several cheap silver cans here the pinion doesnt go on the shaft far enough are these the only motors you have to cut the shafts off of or are others the same. |
