05-01-2010, 03:56 PM | #1 |
Newbie Join Date: Feb 2010 Location: FOLSOM,CA
| Kunfuzed build
This is what I have so far...... Bully light weight axles Jp custom lower links custom bent losi upper links vanquish chassis vanquish v4 wheels .725 hubs front .600 in rear sedona tires proline stage 2 foam FXR novac 45 turn in front tekin 45 turn in rear punk dig DX3R thunder power 3 cell 850 losi shocks in the rear intagy in the front I think that is it.... so far this thing works really good. I am only running 1.5 oz in each front wheel. none in the rear. so it feels light and I like it. |
05-01-2010, 04:33 PM | #2 |
my back yard
05-01-2010, 04:37 PM | #3 |
specs wheel base 12 3/8 front 10 3/4 rear 10 5/8 widths are at widest lug |
05-01-2010, 06:31 PM | #4 |
Quarry Creeper Join Date: Nov 2009 Location: Sunny cali
| Very cool rig there But FYI ! the wheel base should be measure when the chassis is push down so your lower links are level with the ground And it should be no more than 12.5" max according to 2010 comp rule. |
05-01-2010, 07:26 PM | #5 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Not a bad way to spend the day out in the back yard. |
05-01-2010, 07:57 PM | #6 |
some naked pics
05-01-2010, 07:58 PM | #7 |
and how about the mandatory flex shot
05-01-2010, 09:27 PM | #8 |
| thanks i know I'm about an 1/8th over right now at full compresion
05-01-2010, 10:04 PM | #9 |
Rock Crawler Join Date: Mar 2009 Location: AZ
Looking good. What size shocks are you running with that chassis? And are they limited at all? And whats your GC at?
05-02-2010, 02:48 AM | #10 | |
intagy front with pen springs 1/2 inch pen spring to limit down travel and a full pen spring for the up travel And as it sits right now the belly pan sits at 3 1/2 | |
