10-14-2013, 09:08 PM | #1 |
Quarry Creeper Join Date: Jan 2008 Location: Granite Falls, WA
| tf2 XVD 2's
currently testing a set of the new generation of xvd's for rc4wd. now granted these are for the yota 2 axle i managed to get them to fit on my yota 1 axles. first thought on these axles out of the package: BEEFEY! alot more material on the axle itself and the cup containing the cvd. pins appear to be a large diameter also. these also do not use a e clip to retain the axle in the housing. the axle is held in by the outer hub and bearings. i feel this is more convenient for changing parts if needed. no need to fully disassemble the entire axle. installation went like this...grind grind grind on the outer end of the axle. theres just over a mm of difference between the axle housing and the axle pin retaining ring. i had to remove the material slowly as not to comprimise the structural integrity of the axle housing. this took about an hour of careful grinding with the dremel and a metal cutting bit and some grinding stones. alot of cut and fit, cut and fit. after i got the fit just right i discovered that you need to shorten the kingpin screws just about an extra mm or two. once done they are bind free and turn very smoothly. like i said, beefy and well made. 45 degrees of turning angle and im not kidding. i measured it with my protractor after installing these on my tf2. ive had it out 2 times so far. once at a comp that was in the woods (fairly easy trails) the second session was in the rocks. alot of riprap rock. a ton of pinch points and binding of the tires. absolutely impressed with the new xvd's. no failures of any kind. and now my tf2 turns almost as good as my c2 rig (its got all vp front end) im not easy on either of my rigs as i built them to compete and take a beating. ill be adding to this thread as i get more time on these. ill have a pic or two for you also. so far i give these im including a pic of my tf2. for the trail run in installed my c2 tires and rims. still iven with the bigger tires no issues. Last edited by dragonracing; 10-14-2013 at 09:14 PM. |
10-14-2013, 10:25 PM | #2 |
| Re: tf2 XVD 2's
i know that the last version of the xvds were very prone to breakage. ive been assured that these are much stronger. im pretty sure that earlier version left a bad taste in many peoples mouths. im hoping these are the answer for that problem.
10-15-2013, 02:27 PM | #3 |
Rock Crawler Join Date: Jul 2012 Location: Albuquerque, New Mexico
| Re: tf2 XVD 2's
Yeah I hope they are better too. I may pick up the new axle housing to use with these
10-15-2013, 03:23 PM | #4 |
| Re: tf2 XVD 2's
you only needt o change over to the yota 2 fromt axle. if you get them get these ones. XVD Axle for Ultimate Scale Yota II G2 Axle the other ones dont have as much steering as these. currently the complete axle is out of stock but i think you can piece it together. not sure if its the same cost to piece it together or not. |
10-24-2013, 12:49 PM | #5 | |
| Re: tf2 XVD 2's Quote:
Very nice, glad to see RC4WD stepping up! Nice beige Toyota too! | |
10-26-2013, 07:16 PM | #6 |
| Re: tf2 XVD 2's
allright. these are legit. i pushed them very hard today we have a comp coming up at our hobby shop and i worked today to change the pile around. then tested everything we changed. i pushed the truck as hard if not harder than my c2 rig. these held up to everything i threw at them. however i did manage to strip a kingpin screw so i may change over to the yota 2 axle. but im going to try a fix first to see if that holds up. but i did not have ANY issues with the xvd 2 axles. not one at all. i love how sharp it turns now. i have total confidence with these axles. i would recommend a set to all tf2 owners. the ultimate setup is to change to the yota 2 axle but these will fit with mods. |
11-27-2013, 10:16 PM | #7 |
Rock Stacker Join Date: Jun 2011 Location: Tasmania, Australia
| Re: tf2 XVD 2's
It is interesting to note that they have deleted the grove in the axle for the E clip on the Yota II axles. Makes me wonder if the E clip has been stopping the 'end float' movement of the axle causing it to load up and break out the edge of the cup as everyone is seeing. Cup is still way too thin agreed. I wonder if anyone has tried the Yota 1 XVD's int he Yota 1 housings WITHOUT the e-clip with any notable improvement?? I'm just waiting to hear back from RC4WD at the moment to see if they are going to come to the party and replace a XVD from my TF-2 which failed after all but 15 minutes gentle use. Have also read that there was some people had noted that the small pin was slightly too short and could have been a contributing factor in the high failure rate of the Yota I XVD's?? |
11-28-2013, 10:16 AM | #8 |
| Re: tf2 XVD 2's
good posibility. the cup on the new xvds are a bit thicker and the pin is a little bigger and fits better. im still running them with no issues. i greased them up pretty good to cut down on wear. so far no troubles. they work great. i still need to replace my yota 1 axles witht he yota 2 version. (stripped kingpin) figured instead of buying another housing ide just buy the whole axle. and i think rc4wd should replace your bad axle. try running without the clip and see if that helps. |
11-28-2013, 12:40 PM | #9 |
| Re: tf2 XVD 2's
I'll try taking the clips off of mine. I have a feeling it won't help. But I'll post results since I plan on switching to yota2 axles anyway.
11-28-2013, 10:00 PM | #10 |
| Re: tf2 XVD 2's
by the way. the new xvd's turn much farther than the old ones do. from 35`on the old to 45` on the new ones. it turns like my ax does with vanquish axles.
12-01-2013, 06:58 PM | #11 |
| Re: tf2 XVD 2's
Another day of punishment in the books. no failures. these are legit. the 45` of turning radius really helps alot. lately ive been having terrible runs in the comps. today i had my best runs in class one. perfect score -20 in one run and a -7 in the other. with my 60 scale points in in the top 3 as far as i can figure. we had some very tight corners to get to the gates today and the addition turning radius was a super bonus. guys go pick these up. mod your axles if you have to or buy the yota2 front axle and your tf2 will perform so much better. and you dont have to worry about breakage. i sure dont. I had to loan out a stock axle end to another competitor who broke a stock axle end today. |
12-03-2013, 11:31 PM | #12 |
Pebble Pounder Join Date: Oct 2012 Location: Canada
| Re: tf2 XVD 2's
I've gone through 4 or 5 sets of XVD now, all failed because of the thin wall tearing apart (all have been the same side - the longer of the two) Leaving the clip out on one set didn't stop the failure. The new xvd do look promising, but I've lost some faith in the rc4wd product- love it but I can't count on reliability. Had diff gear problems too' axle housings that need rework right from new etc....trying to decide if I should roll the dice on another rc4wd experiment.....? However RC4WD have always been good on the warranty - thumbs up for that!! |
12-04-2013, 06:02 PM | #13 | |
12-27-2013, 11:21 PM | #14 |
| Re: tf2 XVD 2's
sadly i must say i no longer own this rig. she has been traded off. the axles still going strong at last report. i traded of this rig for an onroad racer (my true calling) i still have my c2 landcrusher and i wont give that up. so i must say adios to testing the axles. they took some serious punishment and performed beautifully. buy these with confidence. mod to make fit in yota one axles or if you have yota two axes they drop right in. 45 degrees of turning angle really helps the tf2. thanks to rc4wd for the support and the axles. doug. |
12-27-2013, 11:59 PM | #15 |
Rock Stacker Join Date: Dec 2010 Location: junction city
| Re: tf2 XVD 2's
its really hard to read your reply, my eyes keep gravitating to your avatar
12-29-2013, 06:21 PM | #16 |
| Re: tf2 XVD 2's
yeah sorry bout that. lol. shes a keeper....i wish. lol.
01-07-2014, 03:37 PM | #17 |
Rock Stacker Join Date: May 2012 Location: Bend
| Re: tf2 XVD 2's
I am looking for some how-to's on installing these on my new Gelande? Anyone have a link? |
01-07-2014, 04:01 PM | #18 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: tf2 XVD 2's |
01-07-2014, 05:47 PM | #19 |
| Re: tf2 XVD 2's
So all I need to do is take the c-hub off and slide the old out and then slide the new one in?
01-07-2014, 06:20 PM | #20 | |
It is because of the washers and e-clips that are on the axle shaft near the diff. It seems that you'll have to remove the knuckles and then pull out the axle shafts. You may have to remove the 3rd member... Last edited by Lentsnh2012; 01-07-2014 at 06:25 PM. | |
tf2 XVD 2's - Similar Threads | ||||
TF2 XVD Question | BMoreScale | RC4WD Trail Finder 2 | 3 | 02-22-2013 08:24 AM |
Xvd | reden | Newbie General | 4 | 01-13-2011 02:13 PM |
Xvd | dragrcr | RC4WD Bully | 0 | 07-26-2010 05:18 PM |
Rc4wd xvd | HiloDB1 | Kyosho Crawlers | 34 | 11-20-2009 02:44 PM |
