Thread: 4 Link for TF2 possible on Marlin Crawler??
Old 02-04-2021, 09:31 AM   #1
Default 4 Link for TF2 possible on Marlin Crawler??
I was wondering if any of you have used the RC4WD TF-2 4 link kit on the Marlin Crawler. Will it work without modification? How about the 3 link with panhard?
Atitagain is offline   Reply With Quote
Old 02-04-2021, 09:46 AM   #2
Default Re: 4 Link for TF2 possible on Marlin Crawler??
I linked mine a few years ago. Easy swap with no modifications.
Gvus is offline   Reply With Quote
Old 02-04-2021, 10:51 AM   #3
Thank you
Old 02-04-2021, 11:08 AM   #4
No problem.
.... I did eventually get the locked up rc panhard mount. The rc4wd one bent after a lot of hard use. You do have to grind/file down a small spot on the axle for clearance.
Old 02-04-2021, 05:47 PM   #5
I ordered the kits today. Thanks for your help.
Old 02-04-2021, 06:51 PM   #6
My brother broke the panhard mount after a minor tumble, cheap aluminum as usual.
HumboldtEF is offline   Reply With Quote
Old 02-15-2021, 05:42 AM   #7
My kits arrived. The 4 link worked fine. The 3 link and panhard not so much. Seems someone put the wrong panhard mount in the bag. The holes in the mount don't line up with the frame holes. The panhard mount also has three holes in it. After looking at some close ups of other TF2 mounts, I can see that it is the wrong one.
Old 03-05-2021, 06:45 AM   #8
Finally got the right panhard chassis mount from RC4WD. Going to try it out tomorrow.
Old 03-14-2021, 06:20 PM   #9
Lockedup RC has a link kit for the TF2 that has beefier mounts. I picked up the front 3 link kit and installed it on my Marlin that I am building up with a 4Runner body.
The mounts that Lockedup RC sells are alot stronger than the RC4WD mounts. You can purchase the full kit or individual pieces.
ToyotaKing88 is offline   Reply With Quote
4 Link for TF2 possible on Marlin Crawler?? - Similar Threads
TF2 Marlin Crawler Toyotarc RC4WD Trail Finder 2 39 10-17-2019 04:24 PM
Tf2 kit or marlin crawler treadway47025 RC4WD Trail Finder 2 8 03-25-2018 01:04 PM
