Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Spare on the Back of Scout?
Old 04-01-2020, 10:11 AM   #1
Default Spare on the Back of Scout?
I'm thinking the tailgate-mounted spare may negatively impact the truck's crawling - climbing specifically. You know, more weight behind the rear axle, unweighting the front tires.
Anyone mount the spare and notice a difference?
Just trying to solve the world's important challenges here.
No2Mud is offline   Reply With Quote
Old 04-01-2020, 10:58 AM   #2
Moderator
JatoTheRipper's Avatar
Default Re: Spare on the Back of Scout?
Besides raising your center of gravity and changing your front to rear weight balance, spares also affect your departure angle. The spare often drags on the ground when going up hills or dropping off of things.
Old 04-01-2020, 11:14 AM   #3
Much agreed on the departure angles and weight. I actually like the way it looks and before I got the axe I put two 3oz wheel weights on the chassis up front and zipped tied them down. Now that Real car tire weights lol. Cheap and effective way to keep the front end down. They are zipped tied down right in front of the steering servo.
djr01974 is offline   Reply With Quote
Old 04-01-2020, 11:41 AM   #4
You mean like the time a 38" Swamper blew out the back window and landed in the back of my friend's CJ5 when we dropped off a small ledge?
thx
Old 04-01-2020, 11:42 AM   #5
I like the counterweight idea - simulates that 600lb 304 V8
Old 04-01-2020, 12:59 PM   #6
Would be nice if someone made a rear bumper with a tire carrier that fit well. I think I've only seen 2 or 3 rear bumpers for the gen8 and none had a tire carrier
xtreme4x2 is offline   Reply With Quote
Old 04-01-2020, 08:14 PM   #7
Here is my axe with the same weights in the front
Old 04-04-2020, 06:14 PM   #8
As far as effecting its crawling ability, it will do just that. Especially for crawling. I put my spare on over a year ago when I first bought it and yes, it made uphill harder on the rig. But, at the time I didn't care cause I liked the look. If you really want to put it on, have some extra weight up front to make up for it. Just know, the spare rear will get hung up on rocks on steeps climbs
Gamer707b is offline   Reply With Quote
Old 04-06-2020, 10:26 AM   #9
Ive tried to make mine as little of a hindrance as possible. But ive still been considering taking it off, but dont want to deal with covering the hole in the rear.
I removed the foam from my spare, and i am only runnimg the outer beadlock ring to save a little weight. It was still getting hung up, so i cut the hex off the carrier and made a bracket that raised it about 3/4" and leaned it back ahainst the rear window more. Doesnt hang except on straight ledge drops, but i still think the weight could be a small factor. My scouts close to 10lbs at this point so not sure how much the 5-6oz spare is really doing though.
Nogman is offline   Reply With Quote
Old 04-06-2020, 11:09 AM   #10
I'm mostly okay with the departure/drop-off issues. I want the truck to be as close to "real" as (realistically) possible. Real trucks have to watch how they drop off ledges, etc. But, I would like to see it mounted like we would with a full-size truck - higher, angled back toward the window... like you did @Nogman.
Spare on the Back of Scout? - Similar Threads
Added Weights vs. Spare Tire Back End relay1 Axial Yeti XL 8 04-28-2015 07:54 PM
boy scout switch back trail todays pics 8/11 azwheelman Arizona 32 08-15-2013 12:38 AM
boy scout switch back trail todays pics azwheelman Arizona 24 07-03-2013 05:08 PM
