06-16-2021, 01:49 PM | #1 |
Newbie Join Date: May 2021 Location: Bellingham
| Everest 10 twist
How can I reduce or eliminate the torque twist on this truck? I've moved the spring spacers around to reduce it, but I put a larger motor in it and a lipo and its gotten worse. Kid likes to go fast and climb hills. Should I just look into a different vehicle or is it possible to move anything around to eliminate or further reduce the torque twist? Last edited by D-Dub; 06-16-2021 at 02:12 PM. |
06-16-2021, 03:28 PM | #2 |
| Re: Everest 10 twist
sway bars are the easyest way to reduce torque twist but there are some ways to do it that cost a bit more like a skid plate that moves the lower links inbound and down making the link geomitry alot better you can move the upper links were they mount to the axle further apart about the same as the lower link at the skid plate and then theres the pen spring mod were you remove the spring on the shock and replace it with the tiny spring out of a pen i cut mine in half so i only needed 2 pens but dependihg on how fast and.how.big the hill sway bars might still be needed on top of everything else the e10 is a clone of a vary old truck and redcat never bothered to improve it but making it better is half the fun and theres so much to learn from the e10 |
06-16-2021, 03:51 PM | #3 |
Thanks for the ideas! I will look into them. Yea I have been playing around with moving the shocks out, swapping the links in and out, I took the shock spacers out, and that at least keeps it from rolling over on a hard launch or bounce. Also moving the links to the outside holes on the bottom seems to have lowered it slightly and given it a little less roll. Less angle on the drive shafts too. |
06-16-2021, 03:54 PM | #4 |
I noticed there is next to no torque twist when going in reverse. Would flipping the motor and transmission around provide any benifit?
06-16-2021, 09:12 PM | #5 |
Rock Stacker Join Date: Jul 2019 Location: Bullard, TX
With my E10, moved the top of the shocks about an inch towards the center to lower the height and soften the spring rate. Also replaced the skid with one from Road Dog RC to move the links in. I was running a 35t and lipo. Still has some twist but really performed well. Any aftermarket skid for a Gen 7 will work too. Sent from my moto g(7) power using Tapatalk |
06-16-2021, 10:02 PM | #6 | |
| Re: Everest 10 twist Quote:
Did you jus drill new holes for the shocks? | |
06-17-2021, 05:04 AM | #7 |
| Re: Everest 10 twist |
06-17-2021, 03:59 PM | #8 |
Awesome, I used a couple M3 nuts for spacers on the shocks. I was just playing around and used the body mount post holes, about 1.5 inch in from the factory locations and it flattened everything out and no more torque twist AT ALL. Did some test driving and holy cow, this thing will crawl over anything now that the cg is about 2" lower. Only issues I have now, is the driveshafts rub on the links, and the links hit the battery tray on the end. Ill have to see if I can swap them around to keep that from happening and cut back some of the battery tray. Ill probably do what you did and drill another hole about an inch in to mount the shocks out a little more so I have more travel down. Thanks for the ideas! |
06-17-2021, 04:40 PM | #9 |
Flipped around the front and rear inner links to bow out instead of in to clear the drive shafts. 3S just ate a drive shaft on my first run in the dirt. Looks like I'm doing something right. |
06-17-2021, 06:21 PM | #10 | |
and if you want to run 3s your gona want to swap axles the redcat axles dont like 3s but will last a life time on 2s well maybe not but you get the idea but there still vary limited so differnt axles are a good idea | |
06-17-2021, 06:36 PM | #11 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
No idea why, but Redcat is selling the entire front axle assembly from the Gen7 Pro for a whopping 25 bucks. Including CVAs, servo mount, even half of the center driveshaft. I mean, the Redcat CVAs by themselves are like $17-18 a pair.
06-17-2021, 08:17 PM | #12 |
i used one of those axles on a project it broke in 3 places in seconds the axle shaft snaped the chub broke and the shock mount broke off i think it was a bad run and some one is just dumping them
06-18-2021, 12:21 AM | #13 | |
Replacing the driveshaft and will be sticking to 2S. | |
06-18-2021, 09:29 AM | #14 | |
Rock Crawler Join Date: Aug 2005 Location: Augusta
https://www.thingiverse.com/thing:4874315 | |
Everest 10 twist - Similar Threads | ||||
Redcat Everest Gen 7 & Everest 10 Crawling at the Creek | DavidRCBasher | Videos! | 1 | 02-09-2020 04:52 PM |
Everest 10 | Alberto72 | Redcat Crawlers | 4 | 03-03-2018 07:46 AM |
Everest 10 torque twist | JoelTGM | Redcat Crawlers | 14 | 04-11-2017 04:30 PM |
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
Everest-10 | rodney m | Redcat Crawlers | 1 | 08-13-2015 07:17 AM |
