04-28-2016, 12:08 PM | #1 |
Newbie Join Date: Apr 2016 Location: Punta Gorda
| Upper Linkage Set RCT-T020
Just purchased a new RS10xt red and one of the upper linkage black plastic ends with the hole was broken, anybody know of a replacement (just the black plastic end with the hole) the manual parts list no. is RCT-T020 and that's for a pair with the rods. Maybe traxxas sells just rod ends but I don't know the size I measured ball size 5.8 mm, hole inside diameter 5.45 mm. thanks
04-28-2016, 02:33 PM | #2 |
RCC Addict Join Date: May 2011 Location: at home
| Re: Upper Linkage Set RCT-T020
there are many things you can do at this point. be aware you have two different size balls. the suspension links have balls with 2.5mm holes whereas the steering links have balls with 3mm holes. the balls are easy to swap out. I am sure someone around here can donate a rodend or two, I have several. for now you could use one of the rear steer rod ends and change the ball till you get some new rod ends in. if you plan to make links in the future, now is a good time to start, at least shopping for rodends and material to make links. redcar racing will send you some if you want to put off making links. you can get any rodend to fit but the lengths are al a bit different but that is no big thing unless you are a perfectionist. where is fat point? I could try sending you a few if you want. |
04-28-2016, 09:43 PM | #3 |
I went online to Redcat and completed a warranty claim, will give them a try first. I live in Punta Gorda FL between Ft. Myers and Tampa. Only hobby shop within 10 miles is a nitro rc place but they carry a lot of REDCAT PARTS BUT NO LINKAGE FOR THE RS10.
04-29-2016, 10:42 AM | #4 |
welcome to the madness we will all try to help as we can. i am up the coast into north Carolina, anything i can help with let me know. pictures pictures pictures haha |
Upper Linkage Set RCT-T020 - Similar Threads | ||||
Best Steering Linkage Upgrade set for SCX10 ?? | 5VoltDetonator | Newbie General | 5 | 01-10-2013 08:26 PM |
Axial linkage set? | C_Money | Newbie General | 13 | 06-06-2010 04:05 PM |
Rcp axle pics and upper linkage adjusted | TRA3905 | Axial AX-10 Scorpion | 4 | 02-05-2008 07:44 AM |
12.5" linkage set up? | burnurban1 | Tamiya TLT Crawlers | 5 | 01-24-2007 02:30 PM |
