Go Back   RCCrawler Forums > Vendors > RPP Hobby
Thread: In Stock! Axial Ram Power Wagon 1/10th Scale Electric 4WD - RTR
Old 09-25-2014, 11:31 AM   #1
RPP Hobby's Avatar
Default In Stock! Axial Ram Power Wagon 1/10th Scale Electric 4WD - RTR
The SCX10™ Ram Power Wagon is modeled after the toughest civilian 4x4 truck on the planet. This legendary Ram pickup is now available for heavy duty service work on the jobsite during the week and trail adventures with all your friends on the weekends. The beautiful two piece body can be split and used with the AX80046 SCX10™ Roll Cage Flat Bed Set (not included). The details in the front grill and both bumpers really sets this vehicle apart. As always, you can expect top level trail performance from this offering.
Take a legendary Ram truck platform, mate it to the legendary SCX10™ trail truck chassis, and you have a combination that is hard to rival. The SCX10™ Ram Power Wagon is ready when you are to tackle even the harshest off road terrain.
ABOUT RECON G6
Founded in 2009, the RECON G6 event series is a lifestyle, an R/C scale fun adventure for the entire family. Most R/C events through history have been held on closed courses. RECON G6 events are held in outdoor environments making use of the natural terrain. RECON G6 events are based around adventure, battling the environment and building camaraderie with fellow competitors. This is very much the same type of competitive event as the globally famous Camel Trophy Cup. Like these events, RECON G6 events are point to point challenges with special skill sections pitting man and machine against the elements. R.E.C.O.N. has a goal to help drivers be the best R/C driver that they can be. R.E.C.O.N. will achieve this goal by constant commitment to driver training, designing challenging courses, rewarding good driving, and instituting the values of sportsmanship. R.E.C.O.N. understands that success does not come without adversity and how a driver handles adversity defines their character. R.E.C.O.N. will encourage drivers to strive for success, but to accept adversity with professionalism and integrity.
PROVEN DURABILITY - AXLES DESIGNED WITH PERFORMANCE AND DURABILITY IN MIND
The axles have been designed with many features that are not available from other products on the market. Everything from the axle strength, pinion angle, caster, and ground clearance were taken into consideration when designing these axles. The result is a far superior axle that will stand-up to some severe punishment. To ensure added longevity from the start, a high-tolerance sintered diff locker is included along with hardened steel axle shafts.
WB8 HD WILDBOAR™ DRIVESHAFTS
The WB8 HD Wildboar™ Driveshafts feature an updated design with a larger diameter cross pin (2x11mm) along with an M4 Screw Shaft (2mm hex drive) for added strength. A center splined slider floats between each end and features added material which reduces flex and fatigue.
• 3-piece driveshaft with strengthened slider-floater tube.
• Increased surface at the connection between the ball joints and output shaft tubes.
• 2x11mm cross pin adds 25% more surface area providing more strength for the ball joint.
• Captured cross pin design eliminates older set screw design for more durability and easy maintenance.
DUAL SLIPPER CLUTCH
Our dual slipper design uses a pad on each side of the spur gear for added surface area. This allows for more precise tuning and holding power. The spur gear features strong, 32 pitch gearing for high torque applications.
AE-5 ELECTRONIC SPEED CONTROLLER
The Axial AE-5 ESC is 3S LiPo capable yet easily switched “in the field” between LiPO and NiMh battery types with a simple jumper – no more complex procedures.
• Jumper 1 provides a simple plug and play choice between LiPo or NiMh.
• Jumper 2 switches Drag Brake settings.
• Waterproof design with waterproof On/Off switch / standard plug / laser etched heat sink.
METAL GEAR TACTIC SERVO, 151 oz-in
The included Tactic TSX45 metal gear servo is rated at 151 oz-in of torque for massive turning power and dual ball bearings provide smooth and precise movement for the metal gear train.
Other Specs:
Width: 9" (229mm)
Length: 19.4" (492.8mm)
Height: 8.75" (222mm)
Wheelbase: 12.25" (311mm)
Ground Clearance: 2.5" (63.5mm)
Weight: 3.98lb (1.8kg)
Motor: 27T 540/550 size
Radio: 2.4GHz, Two Channel
Servos: One, high-torque metal gear
ESC: Forward and reverse ESC
Items Needed to Complete:
(1) 7.2V Stick Pack Battery
(1) Battery Charger
( AA Batteries
RPP Hobby is offline   Reply With Quote
In Stock! Axial Ram Power Wagon 1/10th Scale Electric 4WD - RTR - Similar Threads
Axial SCX10 Jeep Wrangler G6 1/10th Scale Electric 4WD - Kit aircooled General Crawlers 47 08-23-2015 06:12 PM
Unofficial SCX10™ Ram Power Wagon 1/10th Scale Electric 4WD - RTR Link SuperRoo Axial SCX-10 17 09-03-2014 09:12 AM
Axial Ram Power Wagon 2015 OkinawaCrawler Axial SCX-10 9 08-27-2014 08:27 PM
Axial SCX10 2012 Wrangler Unlimited Rubicon 1/10th SCALE ELECTRIC 4WD - RTR RPP Hobby RPP Hobby 32 01-19-2013 08:19 AM
You may edit your posts
