07-22-2008, 05:08 PM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: bay area
| My R2D servo setup
I just wanted to share with you guys a simple way of mounting your servo for the R2D. I drilled two holes on the tranny and used the battery plate off the scorpion. She shifts great and will easily go back to 4wd from the dig position.
07-22-2008, 06:17 PM | #2 |
I'd keep an eye on those holes in the tranny the body of the R2D is just aluminum you might consider getting a bolt from the inside with a nut on the outside.
07-23-2008, 02:01 PM | #3 |
thnx for pointing that one out. I assumed that side of the alluminum was strong enough to hold onto the screws. nevertheless I added the nuts for added security preciated it |
