01-10-2009, 09:38 AM | #1 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
| Bullys on a stick...
Im starting this thread in the middle of the build, I didnt figure anyone wanted to see all the mistakes I made. I started with 1/2 aluminum rod, 1/4" alum plate and a mill. Bully Axles jr 8711 15 amp switch 2 55t Integy Lathe motors sidewinder esc cc BEC Heim joints from Mcmaster 1/4" chrome bolts from ace (have to have some bling) Dubro 6/32 rod ends steel brakeline links (for now) Jcustoms body Last edited by jetboat; 08-27-2010 at 03:36 PM. |
Sponsored Links | |
01-10-2009, 10:11 AM | #2 |
Pebble Pounder Join Date: Jul 2007 Location: Shorewood
looks good jet. does your wife know you using her bowls for that?? |
01-10-2009, 10:14 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Cotati
Nice job! Can't wait to see how it works.
01-10-2009, 10:44 AM | #4 |
RCC Addict Join Date: Jun 2005 Location: Prosser
From experience with this same build under my belt, and doing it 3 times, lower the backbone until it touches the top of the motor cans, you will still have plenty of clearance, and it will not have near the axle swing ;) Also, turn the rear motor around if you want better approch for the rear axle
01-10-2009, 10:49 AM | #5 |
01-10-2009, 10:54 AM | #6 |
I thought the same thing both times I made lowering brackets, but trust me, you will like it mucho more |
01-10-2009, 12:03 PM | #7 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
That makes at least three MOA rigs amongst the SCRC members, rumor has it there's more to come Sweet rig Jeff |
01-10-2009, 03:06 PM | #8 |
Newbie Join Date: Nov 2008 Location: Bedrock
That's wild that you have the shock towers sticking out of the body. That's the first time I've seen that done on a r/c vehical. I thought you were going to get a bug body. Does your truck run yet?
01-10-2009, 03:16 PM | #9 |
Rock Crawler Join Date: Jun 2008 Location: Lemont, IL
so who has the third "known" one? and who is thinking about it we gotta set up a MOA GTG, figure out what these things are capable of |
01-10-2009, 03:37 PM | #10 |
MOA rigs Mnster, Wojin, D_dogg, ced rc (just a guess) It was running/driving but, I didnt like the mount for the DIG so I desoldered it and made a new mount. Jeeper_05's truck is setup very similar to mine with the shock towers coming out of the body. I tried the bug but, after cutting it all up, I didnt care for it. |
01-10-2009, 05:07 PM | #11 |
01-10-2009, 06:24 PM | #12 |
01-10-2009, 09:23 PM | #13 |
Bug bodies are ugly anyways. They work good though. I would never have a bug body. What is that brand body that you bought for it? Is that a jpcustoms single cab or what? I just hope it was worth paying that money and building that truck. Because how much better would something like that do compared to a full competion 12.5 2.2 truck. That's what I wonder. Like is it worth paying all that money just to have more clearence.
01-11-2009, 02:08 AM | #14 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
LOL, same body I have. Looks great, but will it perform? Very impressed with it so far.
01-11-2009, 06:41 AM | #15 |
01-11-2009, 09:31 AM | #16 |
| Pretty sure I'm gonna build an MOA rig, undecided between Bully and Berg, I like the design of the Bully's but RC4WD worries me about availability, will repair parts be readily avail? I'm waiting on all you guys to work out the kinks before I build my MOA stick |
01-11-2009, 10:55 AM | #17 |
Ininto a small issue with the dig... On carpet tests it doesnt stay fully locked, really close but allows the tires to rotate somewhat. Normally closed to esc Normally open to ground of motor Switch to pos of motor |
01-11-2009, 11:26 AM | #18 |
updated pictures.. Dig has been rebuilt, only rear lockup right now but as you can see I can add front with my driving I thought this was an appropriate sticker... its under the servo side hilling shouldnt be much of a problem verticle climb? even the esc needs protecting |
01-11-2009, 06:42 PM | #19 |
lookin good. my dig switchs lock the axles pretty damn well.i like doing doughnuts
01-15-2009, 03:47 AM | #20 |
Yeah mine lock pretty good as well. Maybe it's your gearing? I'd test it on the rocks first though. Carpet is a highly exaggerated traction crawling surface. |
