03-22-2009, 05:52 PM | #1 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
| My TK Twister Small 8oz T-Bone Comp Rig Well now that I got my Comp Rig done I thought I would post up a few details and pictures of it. It started off as a box stock Axial AX10 ARTR. This is what it has turned into, tell me what you think of it… The Details: TK Twister Small 8oz. T-Bone Chassis w/ rear 4-link plate ABADK9420 straight 5/16" Lower Links custom cut for my chassis Traxxas upper links Losi 4" Crawler Shocks AX10 ARTR Axles with STRC Aluminum C’s & VP High Steer Knuckles with heavy duty ring & pinion gears on the front axle and Axial Aluminum lock outs & heavy duty under drive gears on the rear axle AX10 ARTR Transmission with RC4WD steel top & idler gears DNA Dig Unit with standard size servo mount using a Hitec HS-5645 MIP C-Spine Drive Shafts MIP CVD’s in the front axle Jet Boat BTA steering/battery/4 link setup TCS Delrin Axle Plates TCS Crawlers Lexan Upper Link Plates HB Rovers White Compound Proline 2.2" Oversized 2-Stage Crawling Memory Foam Mayhem Eng. Green Anodized Spider Aluminum Bead-Lock Wheels Losi Grappler Pro Body w/ Custom Paint By ~w~designs Custom made body top mounts Hitec HS-7955TG Digtal Steering Servo Hitec HS-5645 Digital servo for the Dig Castle Creations Mamba Max ESC Castle Creations BEC set at 6.1 volts Mystery 1500mah 3s 25c LiPo's Batteries Integy 45 turn crawler motor Pics: Pics from the first comp with this setup Topless Had to redrill the skid to clear the DNA dig which also moved the weight forward. Chassis Mod and New top mount body post set up This is how she currently looks Let me know what you think.... Last edited by abadk9420; 09-16-2009 at 03:44 AM. |
Sponsored Links | |
03-22-2009, 06:06 PM | #2 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
nice rig! looks like you did every thing right the first time! great job. that chassis looks to be very nice and i know you one the comp yesterday down there so its obviously a good chassis.
03-22-2009, 06:39 PM | #3 |
Rock Crawler Join Date: Nov 2008 Location: Roseville,Ca
Good looking rig.
03-22-2009, 08:20 PM | #4 |
Pebble Pounder Join Date: Sep 2008 Location: lafayette
nice crawler lol |
03-22-2009, 09:44 PM | #5 |
Thanks guys I am realy enjoying it!!!!
03-24-2009, 02:16 AM | #6 |
Any comments or suggestions are appreciated, I am always looking for ways to improve my crawler performance |
03-24-2009, 03:02 AM | #7 |
Quarry Creeper Join Date: Dec 2008 Location: Paradise/Oroville/ in the hobby shop
thats a comp wining rig..
03-28-2009, 02:25 AM | #8 |
06-16-2009, 03:34 PM | #9 |
| Update
Changed to a BTA steering set up, aluminum wheels, and now running on 3s lipo's, man what a difference. here is some updated pics. |
06-16-2009, 08:06 PM | #10 |
Quarry Creeper Join Date: May 2006 Location: Taylorsville
where do you buy this chassi?
06-16-2009, 08:37 PM | #11 |
From TK Twister here is a link TK-twister small T-bone chassis |
06-16-2009, 08:45 PM | #12 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
Nice rig, and congrats on the win |
06-16-2009, 11:38 PM | #13 |
Quarry Creeper Join Date: Nov 2008 Location: Boise
Lookin good Curtis. You have been doing pretty dam good with your rig so far but I am sure these new mods will help you do even better |
06-17-2009, 05:46 PM | #14 |
| Thanks that was my first win, I hope i can finally get another one this weekend, but it is looking like we are going to have some pretty good compitition at this weekends comp, so we will see. I sure hope so, I gotta try to figure a way to get a little more steering out of the new set up, but it is definitely a big help with the approach angles |
06-18-2009, 02:34 PM | #15 |
Newbie Join Date: May 2009 Location: Boise, Idaho
Lookin great Curtis! Hope the BTA works for you i'm sure you'll do great I no you can kick my butt!!
06-19-2009, 11:11 AM | #16 | |
| Quote:
But it being toed out when used with my Axial aluminum knuckles is not helping, I hope the new VP knuckles will fix this problem as well. | |
06-20-2009, 01:35 AM | #17 |
what upper links do you run? and do you know how long your lowers are? i'm thinking about ordering this chassis |
06-20-2009, 09:39 PM | #18 |
| The upper links are 102MM Revo push rods, the fronts are Jato turn buckles for the steering if I remeber right as for the length of the lowers just ask the Dogman he knows what length they are for this chassis with this chassis and the dogmans dogleg lower links I am just a hair under 12.5" axle to axle |
06-22-2009, 12:20 PM | #19 |
| Saturdays Comp Pics
Here is a few pics from my last comp. on Saturday |
06-22-2009, 12:28 PM | #20 |
Looking good Curtis Did you get the VP knuckles yet? If so do they help a lot? |
