06-30-2009, 04:25 PM | #1 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
| 70duncan's Hustler Re-build
Well, I have been wanting to make my Hustler a little better for quite some time now. I have been getting info here on RCC and trying come up with some ideas. After reading a post by TURBOFEST. I desided that I could do the upgrades to the huster that I was wanting. I have made some changes, but most of the inspuration came from TURBOFEST. He did a great job on his. Well on to the boring part . My camera took a dump while I was in the prosses of rebuilding. So, some of these pictures are after the build. This has taken a lot longer than I had expected. My 70 Charger got done at the body shop, so it is now in the garage and I have been trying to work on it when I can. Also, my jeep that I use for work has been taking a beating. I work in the oil field, so I am constantly replacing bushings, u-joints, and everything else that falls off on that long bumpy road. Here is the stock chassis. And here is what I cut off. I didn't like the placement of the links being on the outside of the chassis. I also didn't like having a metal skid. So, I removed the metal and made a Delrin skid that would accept internal mount links. Last edited by 70duncan; 06-30-2009 at 04:31 PM. |
Sponsored Links | |
06-30-2009, 04:34 PM | #2 |
This is what the chassis looks like after welding some 1/4" stock to the bottom. And drilling some recessed holes to bolt the links in with. Here is a picture of the two pieces put together. Once again, sorry for the poor picture quality. My camra broke and I am borrowing another. |
06-30-2009, 05:20 PM | #3 |
I won't bore all of you with all the small details inbetween the pictures. But, if you have any questions, please let me know and I will be more than glad to answer them. My camera was broke during all the measuring and re-measuring. It seemed to take for ever to get all the correct measurments for my links. I made the top links out of 3/8" delrin rod, and the bottom links out of 1/2" delrin rod. I use Traxxas Revo ends, and 4-32 all-thread to match them up. I wanted to make the wheel base as close to 18" as possable. So my links were cut to: Front Upper = 6 1/4" Front Lowwer = 6 1/4" Rear Upper = 7 1/4" Rear Lowwer = 6 15/16" I cut them this way, so I could clock my rear axle up. I am hoping this catch less sharp rocks. With these measurments, my wheel base ended up being 17 7/8". On to the pictures. I also made my lower links with adjustable shock mounts. And here is the way I wanted the links to mounted in the skid plate. |
07-01-2009, 12:35 AM | #4 |
Release your anger.. Join Date: Oct 2006 Location: North American Union
Thanks for the pics. Are you going to narrow the cab a bit like TF? Also, How is the front holding up w/o the brace? |
07-01-2009, 08:34 AM | #5 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Looks familiar! Your gonna like all these mods...it really changes the Hustler alot for the better! Nice work so far! That brace is completely unneccesary once the stock skid is cut out. |
07-01-2009, 11:02 AM | #6 |
I wanna be Dave Join Date: Jul 2008 Location: appleton
Looking like a nice start looking forward to meeting up with you on the 16th still want the spare bed at the hotel.....
07-01-2009, 01:49 PM | #7 | |
| Quote:
Yes, I am need of the spare bed . I plan on being in Denver early on the 17th. I couldn't get the 16th off. I will be leaving late Sunday. My family and I are going to spend a few days in Telluride with the jeep . | |
07-11-2009, 07:56 AM | #8 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
Looks good, I'm looking forward to the Red Rocks Comp. Nice to see there will be a couple of other Huslters there.
07-11-2009, 04:32 PM | #9 | ||
| Quote:
Quote:
Sorry for the slow progress . I have been at work a lot this past couple of weeks. I did get out and do some testing with new mods. I found that it is still a little light in the front end. I will get some more progress posted soon. | ||
07-12-2009, 09:28 AM | #10 |
Yeah, I'm picking up Kasper. I have a class Saturday morning, so I'm hoping to stop by RR after that. I'm competing on sunday in supers.
07-12-2009, 10:24 AM | #11 |
Ok, I have some time post up the progress on this build. I clocked the rear axle up, inorder to help with the sharp pointed rocks we have around here. I hope you can see this in the picture ( I am trying to get as good as the pros on taking pictures). This Picture shows the front axle at a neutral position to help keep the weight a little lower. As you can see, I am using some batteries for front weight. I was using these batteries and some of the rear for my power. But I have now made the switch to LIPO. Last edited by 70duncan; 07-12-2009 at 10:26 AM. |
07-12-2009, 10:33 AM | #12 |
This is a picture of the servo mounts that I made. All the servo mounts that I found to buy were way to week . They would eather bend under the load of this rig or they would allow the axle brace to twist. So I desided to make my own. I used 3/16" aluminum angle and just cut it to fit. Drilled some holes and WHALA. I then drilled a hole in the bottom of the bracket and made a brace run to one of the axle tube bolts. This works great . Now the only thing that twists is the tires or the whole axle tube . I will eventually add aluminum axle tubes when the TTR CVDs are out again. But I am not going to take this apart again untill I can find some CVDs. I am headed out today to do some testing . I hope I will have some video and pictures to share when I get back. |
07-20-2009, 05:30 PM | #13 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
That'll never work Hurry up and get those CVDs in the front and quit breaking parts already
07-20-2009, 08:02 PM | #14 |
Newbie Join Date: Jan 2008 Location: Federal Way,Wa
I might have missed it on here,but what are your lower links?
07-20-2009, 11:47 PM | #15 |
Newbie Join Date: May 2009 Location: Littleton
I like your brace. The twisting of the servo mount was one of the weaknesses I noticed right away when I powered mine up for the first time. I'll have to build one like that for mine. |
07-25-2009, 09:25 PM | #16 | |
| Quote:
I still think you should of gotten the Invite to the Worlds:?. The lower links are made of 1/2" Delrin ( Asetal ) Rod. Sorry for long delay, I have been with my family all week. | |
07-31-2009, 07:35 PM | #17 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
The Delrin skid and inboarded lowers is a killer idea and looks great. I'd be a bit concerned though about the structural integrity of the chassis with the nose brace being removed with the belly pan. |
10-16-2009, 01:50 PM | #18 |
I have had some time to work on the Hustler again, so I wanted to try the 1/4 scale servos. They are a lot cheaper than the regualar servos, but do have a little less power. But I wanted to try them any ways. Here are the mounting brackets that I made out of 1/8" aluminum angle. They are very strong, and stiffen up the axle tube . |
10-16-2009, 01:53 PM | #19 |
I also wanted to have BTA steering on the front axle. So this is what I came up with. It is not the best, but works for now while I deside if I want to keep the 1/4 scale servos. Let me know what you guys think of the hand tool made parts :?. |
10-16-2009, 02:50 PM | #20 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
| I like it
Turned out alot better than mine. And the skid plate looks good to |
