Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers
Thread: cboggs' Super
Old 07-20-2014, 06:09 PM   #1
5th D Owner/Driver
cboggs's Avatar
Default cboggs' Super
Time to finally be a part of this section, I picked up Wheels7's super berg he was selling and finished getting it up and running. Here's some specs and pics from how I got it.
Chaotic super chassis
Chaotic links
berg centers with all the light weight goodness
SDS small gears
Dlux delrin tubes
Brood Foresaken 45T motors
BRXL esc's
Hitec 7980 servos with Dlux servo strengtheners
Dluxed out Big bores 4"
Carbon wheels with CI foams
Super Rovers and Sedonas
Dlux knuckles and Wraith uni's
Dlux swaybar
cboggs is offline   Reply With Quote
Old 07-20-2014, 06:24 PM   #2
5th D Owner/Driver
cboggs's Avatar
Default Re: cboggs' Super
Thanks to Dave (Diamond D) I had him take a look at it and briefly run it so we could figure out what needs to be changed before the comp yesterday, so after a bit of tuning it no longer is running droop in the rear and has the shocks internally limited to reduce the crazy amount of flex it had. There are going to be some more changes coming for this like getting rid of the delrin tubes in place of aluminum since I ripped out both servo mounts during the comp and going to put some thicker lower links on without so much bend to them to keep them from bending in half. My quest to build a reliable super that will hold up has begun! Here's a few pics from our season opener comp (Dave borrowed it also for this one).
Old 07-21-2014, 09:09 AM   #3
Nice truck Chris
Ya when I 1st built my Super Switch it also had way to much articulation almost 90 deg. Went from 4" to 3.5 big bores , still had to internal limit them to reduce the articulation to a tolerable amount.
Nice pic's form the season opener
Tom G
Tom G is offline   Reply With Quote
Old 07-21-2014, 10:15 AM   #4
Wanna get? Gotta want.
Erik D_lux's Avatar
Great to see this car up and running!
For the servo mounts, usually the problem is that the servo mount screws are not long enough. You can double check the length if you look inside of the tube. Ideally, the screw should be flush with the inside of the tube. If they are even a little short, it takes a lot of strength away. Worse case, if the holes are stripped from a short screw, you can throw some brass inserts in there and there should be no issue after that.
I am excited to see where this super goes!
Erik D_lux is offline   Reply With Quote
Old 07-21-2014, 10:19 AM   #5
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Helluva fresh start! I wish there was more terrain out here to flex a super on, I miss running them. Nice rig!
JohnRobHolmes is offline   Reply With Quote
Old 07-21-2014, 10:42 AM   #6
That's looking great Chris! Do we see this rig in RI?
Zarizi Tech is offline   Reply With Quote
Old 07-21-2014, 12:09 PM   #7
5th D Owner/Driver
cboggs's Avatar
The front tubes had the brass inserts already and it still pulled out, the rear didnt have them but the screws looked long enough. It'll all get a look over this weekend to make sure everything is good.
Old 07-21-2014, 01:13 PM   #8
Nice rig. Where did you get those wheels?
Dezertdirt is offline   Reply With Quote
Old 07-21-2014, 05:19 PM   #9
That's where this super landed! Nice!
Curcal is offline   Reply With Quote
Old 08-03-2014, 10:31 PM   #10
Awesome... Could you post some pics of the sway bars?? Have you run it with AND without? Advantages either direction??
picklewagon is offline   Reply With Quote
Old 08-03-2014, 11:10 PM   #11
5th D Owner/Driver
cboggs's Avatar
The cars currently torn down getting new aluminum tubes made so I can't post any pics yet. I run sway bars in my sporty in the rear and it does make a difference making the car more stable and predictable especially in off camber/side hill situations. It works very well on a sportsman. I saw no ill effects on the super when at the comp so it will be staying on there. DLux goes into more detail on his findings since he has been running it for awhile now, but I am a believer in the benefits of the sway bar on certain cars. When I get the super back together I'll play around with it disconnected and post my findings.
Old 08-03-2014, 11:47 PM   #12
Thanks, I'm very interested. Any idea what your wheelbase and track width are when it's together?
Old 08-03-2014, 11:56 PM   #13
5th D Owner/Driver
cboggs's Avatar
Things I wanted to check before the tear down but didn't, hopefully I'll have an answer by the end of the week.
Old 08-05-2014, 12:26 AM   #14
Cool, subscribed. Any thoughts on shock oil weights?
Old 08-05-2014, 09:07 AM   #15
5th D Owner/Driver
cboggs's Avatar
Im running 80wt but alot of guys go heavier.
Old 08-16-2014, 10:01 PM   #16
5th D Owner/Driver
cboggs's Avatar
Here's some pics from our comp today. New tubes and link mounts were made by Dan (KingGee) from 7075 aluminum to keep the servo in place and we also took the clocking of the knuckles in the rear back to neutral. Got the best pics when Dave was driving it.
Old 08-17-2014, 05:19 PM   #17
Awesome... Looks fun...
Any video?
Old 08-17-2014, 06:20 PM   #18
Fun times with a new super in the mix. Overall its working well. Get the steering to cooperate and well have us a battle on our hands this season.
KingGee is offline   Reply With Quote
Old 08-31-2014, 07:35 PM   #19
5th D Owner/Driver
cboggs's Avatar
Busted the skid at the last comp, so I had my machinist Dan make me a new one piece skid out of 7075.
Old
New
Old 08-31-2014, 08:17 PM   #20
Schexy!
cboggs' Super - Similar Threads
cboggs' G6 cboggs Axial SCX-10 8 06-06-2014 07:05 PM
