07-19-2020, 08:54 PM | #1 |
Rock Stacker Join Date: Apr 2014 Location: Las Vegas
| Bruiser Leaf Springs
I am looking for suggestions as two what combo leaf springs I should use for the Bruiser. I had the RCWD Red Leaf springs with one to the original kit helper springs on the car. Over time they flattened out. I picked these up recently https://store.rc4wd.com/Soft-Steel-L...r-2_p_347.html I installed all 3 and car is very stiff.. I guess option would be to remove one of the helpers.. which one.. short or longer? |
07-30-2020, 05:37 AM | #2 |
RCC Addict Join Date: Jun 2004 Location: Bruiser Heaven!!!!
| Re: Bruiser Leaf Springs
I have used the leaf springs from the tamiya Ford high lift kit. You will gain a little bit of lift with them depending on how many leafs you use. Sent from my iPhone using Tapatalk |
07-31-2020, 01:58 PM | #3 |
Those are even stiffer. I’m looking for softer
07-31-2020, 03:24 PM | #4 |
Rock Stacker Join Date: May 2008 Location: 90605
Put the helper springs above the main leaf to soften the suspension but still reduce axle-wrap. Taper the edges of the eyelets to increase articulation.
07-31-2020, 03:39 PM | #5 |
Thanks will give that a shot tonight |
Bruiser Leaf Springs - Similar Threads | ||||
Bruiser leaf springs on a Hilux? | OfnaJoe | 1.9 Scale Rigs | 5 | 02-22-2010 04:13 AM |
bruiser leaf springs? | theonek | 2.2 Scale Rigs | 5 | 02-06-2008 03:56 PM |
Bruiser Leaf Springs | Echodawg | General Scale Talk | 10 | 01-04-2008 09:34 PM |
