Super Clod...which pinion for 60t lathe Atlas motors? I have a choice of 60t or 80t at the moment 70's are all out ...I would like to use my stock Clod pinion if possible so which size of motor should I choose? It will be mainly a crawler with some bashing ability so a bit of fun wheel speed ... thanks! |
60 turn is the way to go |
I'd go for the 60t too, and get a 9 tooth pinion for crawling and keep the stocker for a bit of light bashing. Cheers, Paul. :) |
thanks ...does the 9 tooth pinion slow it down? :roll:I'm a total newbie on this subject. |
Yep, the stock clod pinion is 13 tooth, and a smaller pinion gear slows the final wheelspeed. Good luck. :) |
Im still running the 13t pinion on mine and the wheel speed is ok, Im also running 70t motors also. You can still walk faster then it goes......."thumbsup" |
