Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Hand Brothers Bta
Old 05-14-2008, 08:38 AM   #1
Default Hand Brothers Bta
I am having trouble with servo wiggle from my integy servo mounts. Are the Hand bros. BTA the way to go? I'm running HR axle tubes will I still need axle braces. Also do I relocate links from bottom of tubes to top mounts?
CRAWLERWRM is offline   Reply With Quote
Old 05-14-2008, 09:14 AM   #2
I just finished a build with their setup and it works ok. I don't have much run time on the truck yet so time will tell. I am not running axle braces either. I also have the HR axles and have my links mounted on top of the axle, through the predrilled hole in the axle c. My only gripe is that I got my truck bound up at a comp. and bent one of the servo mount plates. I was able to straighten it, but wish they were stiffer. Servo wiggle is minimal but you must be careful to set your epa properly as the servo mount will bend as mine did if your using high torque servos.
Good luck!
MrBadExample is offline   Reply With Quote
Old 05-14-2008, 01:52 PM   #3
where do they sell these?
ussprinceton2004 is offline   Reply With Quote
Old 05-14-2008, 05:48 PM   #4
Or, http://www.rccrawler.com/forum/showthread.php?t=93833
fatbastard is offline   Reply With Quote
