Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: batteries on the outter steering knuckle
Old 05-14-2008, 08:52 PM   #1
Default batteries on the outter steering knuckle
what is the best way to mount my batteries,i want to put them on the outter steering knuckle,i have integy diffs with RC4WD 12 to 23mm adapter/wideners.well the RC4WD adaptors are bigger than the integy knuckle.I run 2 split 4500 mha 8cell pacs,so it will be 4 cells per knucle
budcrawler is offline   Reply With Quote
Old 05-15-2008, 04:38 AM   #2
Holmes Hobbies
CD13's Avatar
I would mount the batteries to a piece of pcv tubing,large enough to go around you knuckle and slid that over the knuckle. Screw a bolt into the pcv tube to the knuckle.
CD13 is offline   Reply With Quote
Old 05-15-2008, 12:23 PM   #3
Thats a damn good idear right there.
4xFord is offline   Reply With Quote
Old 05-15-2008, 05:42 PM   #4
As a way of comparison, if you dont mind having the same batts always tied to your knuckle, here is what it looks like WITHOUT the PVC:
RB_Steve is offline   Reply With Quote
Old 05-17-2008, 10:29 AM   #5
thats it! thats exactly what i was looking for,i will try the pvc idea.This forum is a wealth of knowledge,like an rc thinktank.this is the best forum :-P
Old 05-17-2008, 10:58 AM   #6
yeah,this works great,and i dont mind always having them in my truck,i got 2 10 cell 4500mha packs
Old 05-17-2008, 11:02 AM   #7
i would post pics but i think i have to bribe someone,$20.00 to grease the wheel,seems like a good deal
Old 05-17-2008, 08:22 PM   #8
Anyone know what size pvc for the stock knuckles? I may grab some on the ride home this evening.
agent4146 is offline   Reply With Quote
Old 05-18-2008, 12:24 AM   #9
Yep those are my Knuckles. You can get them at www.jpcustomrcs.com. They were designed to carry 4 Sub C's inside a 3.2 size wheel. so they fit many Wheels that we use on Supers. They also work with stock and aftermarket Tubes and axles. The bearings have been replaced heavy duty ones.
