Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Wheel adapters for TTR axke shafts/cvd's
Old 05-11-2009, 08:15 PM   #1
Default Wheel adapters for TTR axke shafts/cvd's
i am running TTR CVD's and a straight axle in the rear... The rig has 12mm adapters on it now, But what adapter can I use to run a 14 or 17mm hex? I dont want to run the 12mm adapter.. then a 12 to 14...
The shafts are 8mm.
Edit: never mind.. i used google and searched :: GASP::
PEDEcrawlerguy is offline   Reply With Quote
Old 05-11-2009, 08:24 PM   #2
Thunder tech sells different hex sizes for the cvds 14 and 17mm........I think TCS sells them too...........
hope this helps
clodbuilder99 is offline   Reply With Quote
