Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: What's A ClodBuster???
Old 11-18-2011, 06:49 PM   #1
Default What's A ClodBuster???
I know what a Tamiya ClodBuster is but most pics in this forum don't look like a Tamiya Clod.
SO what is and what isn't a ClodBuster?
GMMWICKED is offline   Reply With Quote
Old 11-18-2011, 10:35 PM   #2
Location: somewhere near Los Angeles...or a city looking thingy.
the pics in the clodbuster gallery are all clodbusters, they're just modified or extremely modified. A clod buster is a MOA crawler, kinda like a slightly bigger berg or xr10. most of the clods on here aren't stock. I have a set of clod axles on a pimpcane chassis, making it a clod BASED crawler, like most of the other clod crawlers. hope it helps.
OTHGbronco82 is offline   Reply With Quote
Old 11-19-2011, 08:23 AM   #3
That'll work. Thanks...
Old 11-19-2011, 10:43 AM   #4
technically it's not a crawler, it's a monster truck.
strap624 is offline   Reply With Quote
Old 11-19-2011, 07:00 PM   #5
no problem, strap has a good point, they were originally a monster truck and then someone tried crawling with them and there you go, clod crawler.
Old 11-28-2011, 10:48 AM   #6
It was the first axles that could handle actual crawling and the grandfather of MOA(well actually someone once tried making a crawler out of frog rear axle ) along with the txt/juggernaut being the first shafty crawler.. The bruiser was the OG of "crawlers" but nobody could afford back then to chop up a perfectly good $100+ bruiser axle that would snap and cost a fortune for a replacement axle.
docsrcrepair is offline   Reply With Quote
