Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Maximizer Beadlock Question
Old 12-04-2006, 12:39 AM   #1
Default Maximizer Beadlock Question
Ok, before I ask this, Crawling is new to me and the answer to my question is probably right in front of me. I just ordered my 18" Pimp Cane chassis today. My plans are Clod axles and a set of beadlocks. Do the Maximizer Beadlocks work on Clod Axles? Is there other options for beadlocks other than Maximizer and Axial?
Bryanshere is offline   Reply With Quote
Old 12-04-2006, 12:46 AM   #2
R.I.P. Chip
jason's Avatar
Maximizer, Axial, and proline all make beadlocks. All will require wheel adapters. Axial, and Prolines are for 40 series tires, Maximizers are for maxx sized tires.
I have owned all three and personally like the Axials the best.
I also have a custom built set of 40 series beadlocks made to directly bolt to clod axles, no adapters required.
jason is offline   Reply With Quote
Old 12-04-2006, 12:48 AM   #3
youll need adaptors for them since they are a 14 and a clod is a 12 maximizer and axial are the cheapest places like rc4wd sell metal ones which are pricey
andrewmp6 is offline   Reply With Quote
Old 12-04-2006, 01:07 AM   #4
Thanks for all the help guys, I really appreciate it
Old 12-04-2006, 05:25 AM   #5
the maximizer with the 0 offset do they rub or should i use the adaptors that widen the truck
Old 12-04-2006, 12:47 PM   #6
i'd get the X-75's since they are 3/4" offset. ends up making the truck 1.5" wider
'83 chevy is offline   Reply With Quote
Old 12-04-2006, 01:49 PM   #7
Powered by Awesome
TwistedXT's Avatar
i run maximizer bead locks and some wheel adapters from ACE from here on the board ontop of the Thundertech CVD axleshafts
TwistedXT is offline   Reply With Quote
Old 12-04-2006, 05:20 PM   #8
If you've got the 0 offset Maximizers, our 12-14mm adapters will fix the tire rubbing issue for you. They're probably too wide to use with the X-75 3/4" offset wheels though.
http://www.rccrawler.com/forum/showthread.php?t=50177
CPE MT is offline   Reply With Quote
Old 12-04-2006, 10:31 PM   #9
i dont like the look of the x75 ones cpe i seen yours before are they a inch each side or half a inch each side
Old 12-05-2006, 07:20 AM   #10
They're 1" offset per side. We had continued problems in getting LST wheels to fit without rubbing so we went a little wider than the other adapters available. They'd also work well with the 0 offset Maximizers. Thanks.
