Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: clod motors
Old 12-17-2006, 01:02 PM   #1
Default clod motors
hi every one im new to the rc world and need alittle help.I have a clod with the NN chassis and axle snapper motors.The problem is the lower links hit the motors when flexing causing a bad bind.My question is are the integy motors smaller and would it cure the problem.Any help or direction would be great
jays96xj is offline   Reply With Quote
Old 12-17-2006, 01:22 PM   #2
do u have the links on right? My NN has no problem with any clearance issues. What motor are you runing and what adapter plate if any do you have on the motors?
dugfrompa is offline   Reply With Quote
Old 12-17-2006, 01:24 PM   #3
Are your links on the Inside or Outside of the Chassis ?
Vegasracer is offline   Reply With Quote
Old 12-17-2006, 01:38 PM   #4
if he's running the motors i think he's running they are 1/2 inch longer than a 540 with no mount
traylor4x4 is offline   Reply With Quote
Old 12-17-2006, 04:38 PM   #5
FiremanJim's Avatar
i had the same prob and switching to the integys got me past the point of binding
FiremanJim is offline   Reply With Quote
Old 12-17-2006, 04:44 PM   #6
The axle snappers are longer by at least a half inch. I have axle snappers in toolbox, I'll measure soon. Use the Integy lathes and you have have no trouble.
swaugh is offline   Reply With Quote
Old 12-18-2006, 10:51 AM   #7
yeah , 550 length motors will not clear links( don't ask how I know, just go with the fact they don't ).
jrizza is offline   Reply With Quote
Old 12-18-2006, 11:44 AM   #8
now that means you have to change them huh?
77chevy4x4 is offline   Reply With Quote
Old 12-18-2006, 05:20 PM   #9
Default thanks
thanks for the help on the motor hitting the links. Where can i get the integy motors
Old 12-18-2006, 05:43 PM   #10
frank400's Avatar
the crawler store or tower ,if they have them in stock.
Frank
frank400 is offline   Reply With Quote
