Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: work in progress very,very slow progress!
Old 11-30-2006, 07:29 PM   #1
Default work in progress very,very slow progress!
check out these pics. it doesnt "run" yet, bit i am going to get some radio equipment tommorrow. whatcha think?http://rednekcrwlr.blogspot.com
rednekcrwlr is offline   Reply With Quote
Old 12-01-2006, 06:39 AM   #2
not bad you might wanna sit the body lower try to hide your frame and lower the truck some sitting that high it will flip try painting the hood door or fender a different color or primer the rest you should know lock the diffs better tires
andrewmp6 is offline   Reply With Quote
Old 12-01-2006, 08:21 AM   #3
perhaps change the motors and go for a 45t or 55t lathe motor
Moondust1950 is offline   Reply With Quote
Old 12-01-2006, 05:03 PM   #4
ive already locked the gears. i ordered the radio system and battery today. hopefully ill have it running in a couple of weeks. after the funds replinish we'll upgrade to probably some moabs on alum. beadlocks and the lathe motors. just not enough money right now! lol. may have to trim fenders too, itll rub now if you twist it enough. is there a good way to waterproof the motors?
Old 12-01-2006, 05:40 PM   #5
The simulated rust and faded spots are sweet....
mr.maxx is offline   Reply With Quote
Old 12-01-2006, 08:10 PM   #6
Originally Posted by M715ForLife
Its called puncuation u slack jawed yolkel!
"It's" called spelling you fawking moron!!!!
Robb is offline   Reply With Quote
Old 12-18-2006, 09:48 PM   #7
Default update
well i finally got all my radio gear installed, run it about ten minutes, rolled off some stairs, and realized the need for aluminum link mounts. oh well.
