Broken? clod axle. 3 Attachment(s) My truck was working fine last time I used it. Today the front axle wont spin. I have stripped it all down and the parts shown in the pictures will not rotate. These are parts of a thundertech CVD. Does anyone have any idea how to make it work. I have tried to turn it with a pair of grips but it will not move. |
To me it sounds like the bearings are giving you the issues. Will the axle not rotate or is it the knuckle won't turn? |
I'm going to go with the pin slipped out and is jammed in the knuckle. Did you put it together? Do you recall using loctite on the set screw? |
1 Attachment(s) Hi Run2 thanks for the reply. It is the actual axle that will not turn. I have just inspected again and noticed something shiney in the hole that secures the screw that fastens through the knuckle. Inside there was a small pin that secures itself within the CVD. This small pin had "fallen"out of its hole and wedgein the hole that the knuckle screw is installed in. This acted as a wedge and stopped the axle turning. This small metal pin sits inside a plastic fitting. Can I use threadlock to secure it? |
Hi Unholy. You where right. I did not put the axles together. I bought the truck from Syco and it was already constructed Looks like loctite will be installed tonight. Thanks |
There is a set screw that secures the pin. That's what you loctite. |
UNHOLY thinks he knows it all.:) |
Well actually Run2 I should not say this But....... Unholy sent me a pm and told me to take no notice of you as he knows more than you anyday of the week. I would have sent it to you but unfortunately I deleated it :-P |
I already knew he did....:) I'm still learning things everyday. |
I'm just mad at run2jeepn because of this post. http://www.rccrawler.com/forum/showp...8&postcount=37 In response to what got him started. It's all his fault! And I learn stuff every day on here too... and some people think the site is waste... :roll: |
Well at least inspired one human being...:) |
