04-16-2007, 07:48 AM | #1 |
RCC Addict Join Date: Dec 2005 Location: Beaver Falls
| axle link brackets
I noticed rc4wd has brackets to attach links onto clod axles but i can't get myself to ditch out $30 for them. I know some of you guys made your own. Would you mind sharing your ideas? I think i can make my own but with limited tools, it might be quite difficult so i'm looking for that easy fix if it's out there. I already have the holes drilled on the knuckle and with the link directly attached to it, it doesn't get enough clearance to twist properly so i know it has to be mounted away from the knuckle. Could i just use a simple spacer and nut/bolt and mount it about 1/4" away from the knuckle? I don't know if that will be strong enough.
04-16-2007, 07:57 AM | #2 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
Are you using conical washers with your current installation? We use those and have no problems with lack of articulation. Some of the adapters you're talking about cur down on axle clearance as they mount above and below of the axle tube itself. |
04-16-2007, 08:01 AM | #3 |
No i ain't using those. It's actually the first time i've seen those. Do those act as "spacers" to push the mounting point away from the knuckle? Are those order items or can i get them locally somewhere? I had an idea of using some extra end link balls i had laying around as spacers. Last edited by muddeprived; 04-16-2007 at 08:04 AM. |
04-16-2007, 08:05 AM | #4 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
no, they have the beveled edge allowing the rod end more movement, and yes, it does act as a spacer but not really its primary use. CPE MT, where did you get those at? the only ones i've found were from yeah racing i got from wallawalla. |
04-16-2007, 09:50 AM | #5 |
Rock Crawler Join Date: Apr 2006 Location: louisville
you mean these http://rc4wdstore.com/product_info.p...roducts_id=166 if so they are a waste of money for a crawler they are ment for racing and jumping most of us mount the lower link on the axle stay hole with a conical washer
04-16-2007, 12:44 PM | #6 | |
Pebble Pounder Join Date: Oct 2006 Location: raleigh, nc
http://www.crawfordperformanceengine...P6&log_pid=yes New Era Models also has them: http://www.neweramodels.com/cgi-bin/...=&part_id=3198 | |
04-16-2007, 07:23 PM | #7 |
I was going through all the bits and parts i had laying around for my clod build and noticed a good looking set of nuts i had that were supposed to be used on the clod. The nuts are shaped like conical washers and fit on the bolts i use for the links perfectly. I stuck one nut on against the knuckle and then the rod end and finally another nut. Now it can flex like it should with no binding against the knuckle. I guess i don't have to order conical washers after all The nuts came from the clod parts bag B. There's a shi$load of them in there. |
04-16-2007, 07:29 PM | #8 |
| i run bretts CPE conical washers on ALL my clods. on both sides of the link ball. i think i have 4 of the 16 piece sets |
