05-19-2007, 05:39 AM | #1 |
Pebble Pounder Join Date: May 2007 Location: United Kingdom, wales
| wheels |
05-19-2007, 06:05 AM | #2 |
Not those. But RC4WD.com has some 14mm Hex's that work with stock Axles.
05-19-2007, 06:05 AM | #3 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
Not the ones you have pictured. Stock Clodbuster axles have a spline that drives the 12mm hex. They do not have holes drilled in them for the pin you've pictured. Integy makes a set of replacement axles that I think have a hole for a pin if necessary, and I'm pretty sure RC4WD now has a 14mm hex that is broached with the stock Clodbuster spline. Those would slide right on your stock Clodbuster axles. |
05-19-2007, 12:58 PM | #4 |
ok thanks i was just making sure so i know what to buy thanks alex |
