Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: clod Axles
Old 11-23-2007, 05:16 PM   #1
Default clod Axles
What all do you need to put a comple set of clod axle toghter form parts?
texase_maxx is offline   Reply With Quote
Old 11-23-2007, 05:41 PM   #2
http://www.jpcustomrcs.atomicshops.c...ge/4515596.htm
Thorsteenster is offline   Reply With Quote
Old 11-24-2007, 07:36 AM   #3
I have found that you are better off finding a used set...after you buy everything individually...you have too much in them...unless you buy just the cases and upgrade the rest...That's what I did.
Rckcrwlr is offline   Reply With Quote
Old 11-24-2007, 07:59 AM   #4
I wouldn't use any stock components, look at RCPcrawlers.com, you can get Integy cases, metal gears and CVD's and have some stout axles.
Old 11-24-2007, 08:31 AM   #5
How are you liking their cases? I was not sure at first...You have been running them, correct?
How are they wearing?
I like the idea of the weight down low...
Old 11-24-2007, 08:34 AM   #6
Actually I don't, but thats what I'll be doing when I build a set of axles for a super. With the cost of Tamiya parts I'd rather build them with beefier aftermarket parts instead of spending money on parts that will get replaced anyway.
X2 on the weight down low.
