12-18-2008, 12:30 AM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: 303
| ARCATT delta 1.9ine
I had to dig pretty deep into the parts box for this one, I really didn't want to try to chop a set of axles to build a 1.9, so I started looking at some wheels...and found some 5 spokes |
12-18-2008, 12:41 AM | #2 |
The Team Losi A-7801 touring car wheel has the right specs to make this work at a -5mm offset, the lhs had another set on the wall, probably for years and years, they measure up right on totally stock axles...close, but right. Holiday build on |
12-18-2008, 07:46 AM | #3 |
Rock Crawler Join Date: Jan 2007 Location: Do I look like a freaking people person?
Is that all you've got?? Come on lets see more. That is close........... almost 8". |
12-18-2008, 09:17 PM | #4 |
-10mm offset is all I got The hexes for these wheels measure up to 9.4mm and are still offered. I drilled them with 13/64 bit to fit the stubs and had to file the slot to fit the fat Tamiya pin. |
12-18-2008, 09:50 PM | #5 |
damn, i tried and didnt like how it was working out so i narrowed my TLTs.
12-19-2008, 01:36 PM | #6 |
RCC Addict Join Date: Oct 2007 Location: Commerce Twp.
We need more pictures of the wheels on the axles, thanks
12-19-2008, 03:24 PM | #7 |
RCC Addict Join Date: Feb 2007 Location: Chucking rocks at your little truck!
The IRON CHEF is at it again.... Don't make me post up my spy shots. |
12-19-2008, 07:31 PM | #8 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
12-20-2008, 08:17 PM | #9 | |
I got jammed up on links but think I should have enough room to stuff everything else in 1 7/8" belly clearance and plenty of flex | |
12-20-2008, 09:48 PM | #10 |
RCC Addict Join Date: Mar 2005 Location: DODGING ROCK CHUCKERS
Damn, nice work..
12-20-2008, 11:42 PM | #11 |
how wide are you with them rims and tires at the wides point.
12-21-2008, 08:52 AM | #12 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Very nice build. Which car did you rob the Losi shocks from?
12-21-2008, 10:27 PM | #13 | |
| 7 15/16 loaded, the wheels camber out on the axle though, it will have to fit tighter to the axle before it sees any ground & pound especially with the mini hex...make it work Quote:
what's fit so far, plenty more to do... GM SX6R Novak BEC Hitec 5645 MG Mirrored Axial Tranny 35 Turn Integy Stock TLT axles with bearings & locked 2 cell A123 Ion's Axial chassis & custom skid | |
12-21-2008, 10:33 PM | #14 |
2 cell A123 Ion's- isnt that only 6.6 volts? Id be curious to see what your run times look like.
12-22-2008, 07:37 AM | #15 |
Damn nice build! |
12-22-2008, 07:43 AM | #16 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
12-31-2008, 07:43 PM | #17 |
| Finally I got a wheelie poppin 20 minutes in with 18/84 gears before the pack went soft, and put back 500mah into the pack, no problem in the voltage area. Maybe a little too perky, I am going to try a 45 turn to smooth it out a little while paint dries |
12-31-2008, 09:32 PM | #18 |
A 20 minute run time doesnt sound too bad. It would get you through any 2.2 comp around here just fine. Going for the bonus gate could be pushing it though. I see mention of paint drying, guess that means youve selected a body? How long are those shocks from center to center? Ive got a similar build in mind but cant find the right length shocks in my parts bins. |
01-01-2009, 10:33 PM | #19 | |
01-02-2009, 08:19 AM | #20 |
RCC Addict Join Date: Sep 2007 Location: WHEAT RIDGE, CO
So....when's it coming out to play |
