Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Scale TLT trail rig
Old 10-01-2005, 03:10 PM   #1
Default Scale TLT trail rig
I got the axles built Wednesday, and the last of the parts I needed for mockup came yesterday, so I tossed on the shocks and made lower links to set the WB an here's what I got:
Today I cut out the body and found the WB was a little too short, so I extended the rear links 1/4" and trimmed the body some more:
Up next:
Cut up / paint the chassis
Paint the body
Make the links pretty
Narrow the wheels
All the other misc stuff
Mazlem is offline   Reply With Quote
Old 10-01-2005, 07:20 PM   #2
thats gonna be a pretty cool little trail rig....
i would presonnaly mount the front steering servo on the chassis .... ya u get bump steer but i have always liked how that looks on a trail rig.
nd4spdbh is offline   Reply With Quote
Old 10-03-2005, 07:14 PM   #3
Here's the chassis cut an painted:
And here's the body painted. I'm not sure yet if I want to tint the windows or not.
Old 10-03-2005, 07:18 PM   #4
youre gunna narrow already narrowed moabs
ILoveRCRockCrawlin is offline   Reply With Quote
Old 10-03-2005, 07:24 PM   #5
can't wait to see it in action .
Bam Bam is offline   Reply With Quote
Old 10-03-2005, 07:44 PM   #6
Im Brandon
Brandon's Avatar
Yup, they still work great, if you get the right foam in them and the sidewalls hold up. Narrowing the wheels from the inside also allows for a necessary widened stance. I assume that is what he is doing.
Brandon is offline   Reply With Quote
Old 10-03-2005, 08:03 PM   #7
The wheels are 1/4" narrower than the tires; taking the inside lip off would narrow them another 1/8" or so. The tires are pretty close to the chassis / links is the main reason I was thinking of doing that. I may narrow the chassis first tho; might be less work.
Old 10-03-2005, 09:04 PM   #8
Im Brandon
Brandon's Avatar
If you narrow the chassis you will have an easier time mounting a tranny. What are you going to use for a tranny anyways?
Old 10-04-2005, 12:41 PM   #9
Actually I'd like to use a TXT tranny, which is the same inside-width that the chassis currently is. That way I won't need a gear reduction; just stick 9T / 12T pinion in there for 45:1 / 56:1 gearing.
Old 10-12-2005, 10:04 AM   #10
Here it is back together with the suspension all done:
I'm getting a band saw tonight so I'll start work on the wheels, foams, and steering links. I want to see if narrowing the wheels will help enough with clearance before narrowing the chassis since the TXT tranny is the same width as the chassis.
Old 10-12-2005, 10:37 AM   #11
looks good !!
kaaina is offline   Reply With Quote
Old 10-12-2005, 12:29 PM   #12
Very Nice! Great job...
Spoon is offline   Reply With Quote
