12-18-2005, 12:01 PM | #1 |
Rock Crawler Join Date: Aug 2004 Location: Concord Ca
| Hilux build up
I have been bitten by the scale Brusier/Mountineer/Hilyx bug. I first had to find a chassis and axles that were complete enough to have a chance of making a decent light duty leaf sprung Trail rig. This truck will not be built as a Resto rig, A lot of the parts are going to be built right hear in the shop for my relaxation and fun. I have opened up the Axles and inspected them. OK shape I did not like the wobble in the king pins and put Teflon sleeves over them and cleaned up the slop. The springs were flat and no movement. I replaced them with a new set of Jug leaf springs and removed two leafs from the back and one from the front. I did not want to remove the centering pins from the springs so I cut the springs to 1/2 of an inch to fit the perch. I did not like the u-bolts that held the axle housing to the leaf springs so I made my own out of all thread and reversed the mounting |
12-18-2005, 03:47 PM | #2 |
RCC Addict Join Date: Dec 2004 Location: Central NY
looks good. where do you find all the replacement parts for the leafsprings? i might use them on my new trail/utility rig.
12-18-2005, 04:06 PM | #3 |
| nice
Looks like a good start, I like the u bolt flip, what telfon spacers did you use on the king pins? I made mine out of soda cans...works ok but teflon ones sound even better Mike |
12-18-2005, 05:01 PM | #4 | |
I also do not like the angle on the drive shafts and want to make my own transfer case with the motor foward and not use a pede or stanard made tranny. It would be cool to have the electric motor look like a trany and put a Plastic motor infront of it in the motor compartment possably. | |
12-18-2005, 05:05 PM | #5 | |
http://www2.towerhobbies.com/cgi-bin...?&I=LXNM39&P=X | |
12-18-2005, 05:19 PM | #6 |
i found the leaf springs but bo shackles and mounts, except for ebay. randy you got pm |
12-18-2005, 05:40 PM | #7 |
Pebble Pounder Join Date: Jun 2005 Location: boston
i cut my leafs like that on a mountaneer i had the leafs kept sagging and i had to bend them back alot. that was with a light 1 speed tranny as well, these are the jugg springs from tower?
12-18-2005, 06:17 PM | #8 |
12-18-2005, 06:22 PM | #9 | |
12-18-2005, 06:58 PM | #10 |
i had mine flipped as well, i made a shim to go under the spring and used all thread as well, i cut the frame and shortend it to fit a jeep wrangler body. the shim corrected driveline and supported spring better than stock, i hope yours works out.
12-18-2005, 10:03 PM | #11 |
Newbie Join Date: Dec 2005 Location: Nashville
you should do like the big boys and cut the axles and rotate them for better pinion angles. Just a thought. By the way...if you could...please keep us updated on this project! I've had a full scale version and it was the best little truck! Last edited by KevanRay; 12-18-2005 at 10:07 PM. |
12-19-2005, 12:47 AM | #12 | |
12-19-2005, 12:54 AM | #13 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
Hey Randy, Got anymore of that teflon stuff? I think I"d like a set. Is that chassis aluminum? I've never seen a hilux in person before. I think we are going to have to have a trail ride in the future. maybe even a leaf sprung comp.
12-19-2005, 12:57 AM | #14 | |
And I will add photos as I build my Hilux, Thanks | |
12-19-2005, 01:08 AM | #15 | |
You got it, it is solid aluminum! I need some time to get it ready so do not plan on the trail run or comp too soon. No four bars hear! well at least this rig.:-) | |
12-19-2005, 01:31 AM | #16 |
Cool, than you have just enough. I think a leaf sprung comp would be awesome. I'll post up in general about it.
12-19-2005, 06:16 PM | #17 | |
12-19-2005, 08:12 PM | #18 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
hey randy, i'd be interested in some of that teflon tubing as well, any idea of where i can pick some up (tap plastic or hardware store)? let me know, thanks. can't wait to see more progress of your hilux!
12-20-2005, 01:04 AM | #19 | |
send to: BBY Racing/att. Randy 1090 Shary Circle Unit F Concord Ca. 94518 | |
12-20-2005, 10:22 AM | #20 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
Are you talking about the softer mounty springs going flat on you? | |
