Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: Grover/azvader and microgoat Inspired TLT.
Old 05-01-2006, 09:57 PM   #1
Default Grover/azvader and microgoat Inspired TLT.
Now that my scale crawler is finished it was time to use up my other pair of TLT axles. I saw azvaders thread about Grovers non cross-memeber chassis. I love the simplicity and cleanliness of the chassis, serious ingenuity.
I started working on the chassis a few days ago and got it a roller tonight, here are some specs and pics of it so far.
specs:
Pede tranny
55t lathe
rooster
Pede sliders
60/40 link setup
Hacked TXT body
2.2 moabs(coming soon)
(using borrowed tires from my other TLT)
pic of the rear links
The FBS(Farm Boy Special) body lives on!!!
Body off shots are coming soon.
bigred is offline   Reply With Quote
Old 05-02-2006, 08:29 AM   #2
what a tease.
Crawlsalot is offline   Reply With Quote
Old 05-02-2006, 09:31 AM   #3
Come on, let's see it!
microgoat is offline   Reply With Quote
Old 05-02-2006, 09:43 AM   #4
yeah show us ;)
Rikpal is offline   Reply With Quote
Old 05-02-2006, 09:07 PM   #5
azvader's Avatar
Default Yet Another is Born
Well...
azvader is offline   Reply With Quote
Old 05-02-2006, 09:35 PM   #6
Originally Posted by azvader
Well...
OK, OK, sorry for the delay.
Here it is, when I built the chassis i didn't plan on running a 60/40 setup, I didn't off set the tranny so the the rear shocks are layed back a bit more then the front.
Im not sure if im going to keep the rear links they take away ground clearance but do give it a unique look. I'm kicking around the idea of a high clearance drive line setup and high clearance links.....
A lot more work and changes to be done......this is step one of many, I'll keep you posted.
Old 05-03-2006, 12:47 AM   #7
azvader's Avatar
Default Brilliant !!!! ( say it like the Guinness guys )
Very nice !!!! I like the shock mounts at the chassis beam. I've been working out what to do on V.2, microgoat's upper link location and your angled shock mounts.
You'll need to stand those rear shocks up or you'll get some unwanted torque roll. Some spacers between the shock and chassis should do.
Old 05-03-2006, 04:07 AM   #8
Genius!!! ;)
Old 05-03-2006, 05:27 AM   #9
As well as this design works, we're going to see a lot more hangers in the coming years. Looks good.
Old 05-03-2006, 11:05 AM   #10
thanks for the compliments and ideas.
Im trying a standard 50/50 link setup that should stand up the shocks, but im also going to run a shorter shock.
I'll have some more pics up in a few.
Old 05-03-2006, 11:24 AM   #11
I love how cleen these trucks look w/o side plates. I am almost temted to rebuild miine(since the active suspension came off it has been a float/flex stick).
good one bigred
Chad-
grover is offline   Reply With Quote
