09-05-2006, 06:17 PM | #1 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
| TLT K2 chassis, stealt trans mock up
Well it hasnt got much of a change but for some dam reason my links are near what I wanted, I mean they are 108mm and 137mm- same size as Eeepees and all other trx revo/maxx link set up! David the links look great, I might have you make me some new upper links tho :( Here she is mock up! Last edited by TLTCrawlin; 09-05-2006 at 06:27 PM. |
09-05-2006, 06:29 PM | #2 |
Rock Stacker Join Date: Apr 2006 Location: North Providence
Locks really nice and yeah them links arent sized right. Also nice dog
09-05-2006, 06:37 PM | #3 |
RCC Addict Join Date: Jul 2005 Location: Provo
have ya tried switching the lowers and the uppers its worth a shot |
09-05-2006, 06:51 PM | #4 |
wouldnt work the chassis has almost vertical holes and where they go on the axle is back further so lol! This sucks!
09-05-2006, 07:13 PM | #5 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
just make some new ones not to hard.
09-05-2006, 07:33 PM | #6 |
I didnt make them, and I think when you cut CF you have to epoxy the ends and I dont have epoxy, and stuff. I think im going to send my whole truck to insane and tell him to put all four links up, I will supply everything but epoxy, hacksaw, & vise! If you are reading this David LMK how much to cut em smaller, the top links that is? I will send the whole truck and LMK on pricing Thanks bro I love hte links tho! |
09-05-2006, 07:38 PM | #7 |
When you mock up the uppers, what wheelbase do you get? They look about right...
09-05-2006, 07:50 PM | #8 |
Eeebout 13" 12.5" wb with lower links instead of upper! |
09-05-2006, 08:18 PM | #9 |
Pebble Pounder Join Date: Aug 2006 Location: Suffolk
Instead of cutting your new links, why not play around with the mounting positions. I've tried about 15 different configurations of the stock brackets. I've put the shock/link mount on the top, bottom and center and turned them around front to back. It looks like if you turn your upper mount around, so the link mount is facing away from the truck, and the shock mount hole is toward the truck it may effectivly shorten the link by moving it further over the axle. Play around with where you have each link mounted before you cut them!
09-05-2006, 11:08 PM | #10 | |
RCC Addict Join Date: Mar 2006 Location: Bedias, Texas
Hey buddy, I think I would do as everyone says and try some different positions first. Here's an example, could you drill 4 more holes in the chassis just a little upward of where the tranny goes, and further in to shorten them to the lengths you need for the lowers to fit? May be worth a try before cutting them. If that doesn't work I can go ahead and repair it anyway you like. Just let me know. Sincerely, David Xtreme rc hobbies | |
09-05-2006, 11:29 PM | #11 |
This chassis has near no triangulation so if I put the holes up more it would be opposite of the triangulation that I need!
09-05-2006, 11:56 PM | #12 | |
David | |
09-06-2006, 04:33 AM | #13 | |
09-06-2006, 07:50 AM | #14 |
I think im going to cut the top ones shorter because the wb is too long, its at 13-13 1/2"s!
09-06-2006, 03:08 PM | #15 |
RCC Addict Join Date: May 2006 Location: Aroostook county
i think that looks sweet |
09-06-2006, 04:34 PM | #16 | |
09-07-2006, 07:33 PM | #17 |
Update, I might have some problems but heres an idea! |
09-07-2006, 07:39 PM | #18 |
Watch your knuckle with the Dremel. Good looking chassis, BTW.
09-07-2006, 07:41 PM | #19 |
Its not my chassis, but it is good looking!!
09-07-2006, 09:22 PM | #20 |
Maybe a dumb question, but, what's keeping your axles from moving side to side? Are you going to run a panhard rod to locate your axles, keep them centered in the chassis? With the uppers and lowers mounted above each other like that, your axles are going to move left and right at will.Maybe I just can't see the pics that well.
