Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: ORCRC dig questions
Old 10-09-2006, 09:54 PM   #1
I'm a stupid C U N T!
Default ORCRC dig questions
So i set up dig according to the ORCRC guide. Anyone else who's done it, can you tell me how you keep from twisting your sliders. I've made 3 of them so far. the first 2 snapped on the test run. Ive tried to remove only the splines to keep them as strong as possible, as well i've run a steel shank through the slider for support. ??? Any tips? Thanks for the help.
slobin3d is offline   Reply With Quote
Old 10-09-2006, 09:55 PM   #2
You need to edit your post.
Old 10-09-2006, 09:57 PM   #3
Any better? my space bar is sticking.
Old 10-09-2006, 11:29 PM   #4
I'll help you if I can, I just finished my dig the other day. It might have to be tomarrow before I reply, I'm going to bed in a few.
War Pig is offline   Reply With Quote
Old 10-10-2006, 11:44 AM   #5
yukon635's Avatar
hey war pig, once the dig in engaged and locked, how are you keeping the male end coming out of the axle from spinning. i know the female end is able to spin freely i am wondering how to lock it into place once in slides down
yukon635 is offline   Reply With Quote
Old 10-10-2006, 11:58 AM   #6
Hey, where did you find the guide? I have been checking their site every once and a while for the past few months and have yet to see it?
Thanks
Destroyer
Destroyer is offline   Reply With Quote
Old 10-10-2006, 12:01 PM   #7
It's still in the forums..
http://rcrockgear.com/bbs/viewtopic.php?t=425
wyattburp is offline   Reply With Quote
Old 10-10-2006, 12:02 PM   #8
Official Cook of the ECC
Scattman's Avatar
Thanks
Destroyer
Scattman is offline   Reply With Quote
Old 10-10-2006, 12:07 PM   #9
Thanks
Destroyer
http://rcrockgear.com/bbs/viewtopic....425&highlight=
LIKES2CRAWL is offline   Reply With Quote
Old 10-10-2006, 12:13 PM   #10
Thanks everyone!
Old 10-10-2006, 12:19 PM   #11
No problem.
Old 10-10-2006, 02:31 PM   #12
miniwheeler's Avatar
Slobin 3D,take some good pics of youre setup and lets see whats broke,I will also try to help
miniwheeler is offline   Reply With Quote
Old 10-10-2006, 04:28 PM   #13
I at the moment dont have a good working camera. but my setup is pretty much the same as yours except that i added a extra support to help keep the brake from spinning as it engages and disengages (sp). the problem i'm having is, that where you have to shave the grooves off the male shaft, it starts to twist and then snap. Maybe i just got a weak set of sliders. I'm on #3 and so far its still intact.
Have you tried adding any kind of lube to setup to help it in and out of brake?
It slides perfectly smooth when everything is ar rest but under and load the arms dont like to move, I'm using a 50oz micro servo, should be good yes??
Old 10-10-2006, 07:11 PM   #14
50oz is plenty, are you adjusting epa's to limit servo throw? if so open the adj up and and move the pivot on the dig lever
as far as the driveline, JB weld the rod in the turned down end of the driveline, it makes it a little stronger and has been working good for me
Old 10-10-2006, 07:21 PM   #15
Yeah, what miniwheeler said. What I did was cut a piece of 6-32 allthread 1/4 in shorter than the length of the 2 male drivelines. Mix up some epoxy and shove it into the hole in the center of the rear down driveline ( the one you removed the splines from) make sure there is alot in there. Then cover half of the allthread with the epoxy and shove it into the driveshaft until it bottoms out, make sure epoxy comes out of the hole at the u-joint end. This is what gives the driveline its strength. Wipe off all excess epoxy before it sets up. After the epoxy dries completely, stick the other end of the allthread into the other driveshaft, this will keep them centered when the dig is activated. Hope this helps. Tim.
Old 10-10-2006, 08:40 PM   #16
Yes i have the Epa's set and right. Its slides like there is no slop in the dricelines at all and when theres any tention on it it wont slide, I'm going to try to open up the grooves a bit, see if that works.
I will try the JB weld on the rod, I had been using CA but it just cracked.
Old 10-10-2006, 10:17 PM   #17
What about using these aluminum male halfs, won't strip or break these...
RD400 is offline   Reply With Quote
Old 10-10-2006, 10:32 PM   #18
MWRCA'er
Mnster's Avatar
Yeah, except he probably won't find them at his local hobby store.
Mnster is offline   Reply With Quote
Old 10-10-2006, 10:39 PM   #19
What so ever do you mean? Doesn't everyone have 3 feet of this sitting on the work bench
Old 10-10-2006, 10:45 PM   #20
yeah that would be nice but I'm pretty sure i havent ordered a set of them for my store.
