03-23-2005, 11:15 PM | #1 |
| XC/CC.. Hummer IFS/IRS suspension help tips wanted
Alright, Over the weekend I picked up a Hummer so I could compete in the ORCRC XC/CC class. I know it's limited but I need to know what I can do to improve the suspension.... Due to the fairly strict rules that ORCRC has setup for the XC/CC class I'm limited to the stock items that are on the rig. I need to figure out how to improve the suspension without altering it too much past stock. I need to pass tech inspection so the modifications can't be too extreme Here's what I've done so far: - Removed rubber stops from inside shocks - Made my own springs to soften the ride What else can I do? Here's how it looks as of tonight..... #1 & #2 pics are of the rear flexed up on a stock TLT wheel, #3 is the front flexed up on stock TLT wheel and #4 is sitting, posing. In all the flexed pictures, all 4 tires are touching the ground(err, table). |
03-23-2005, 11:18 PM | #2 |
Rock Crawler Join Date: Dec 2004 Location: Grand Forks, ND
check on scale 4x4. there is a guy with one of the s10s (i think that this is a similar chassis. he has some extreme articulation with all independent. although i think that that sort of mod would mean that you wouldnt pass inspection. although you could gain some valuable ideas possibly. fuzz |
03-23-2005, 11:22 PM | #3 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
If its like a pajero or touareg you can dremel out some plastic under the a arms to get more droop, like fuzzhead said check out scale4x4 they are a big help till rccrawler gets the scale link up.I hope.
03-23-2005, 11:23 PM | #4 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I ran the F-150 chassis for a while and the only problem I had was breaking the stock axle shafts. I ordered a set of CVD's from Tamiya for the TL-01, never broke another. I don't know if it's allowed?? |
03-23-2005, 11:26 PM | #5 | |
Yeah I saw that S-10 on Scale4x4rc.us I don't think I'd get away with that many modifications. I do know that I need to trim the body to help with tire clearence. Currently the tires rub on the body when the suspension compresses, I hate to trim the hummer body but it'd only be about 2mm or 3mm of material removed. | |
03-23-2005, 11:28 PM | #6 | |
I think shaving some of the plastic away from the A-arms would be fine and I think adding the CVD's would pass too. Hell, I'm not sure if I'm allowed to change springs on the shocks :? But I did | |
03-23-2005, 11:37 PM | #7 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
This is great Toyo. I bought a F-150 last weekend and am building it now. In fact I put one part on it yesterday! Talk about progress! I believe the hummer and the F-150 chassis are the same, so this is perfect timing for this thread. Now figure this shit out so I can steal your ideas! I will update this thread if I think of anything. |
03-23-2005, 11:54 PM | #8 | |
I thought that the F-150 and the Hummer were the same chassis, but I sold my F-150 about 7 months ago so I wasn't positive. | |
03-24-2005, 04:19 PM | #9 | |
Am I not getting the right picture? | |
03-24-2005, 04:28 PM | #10 |
It will give you more clearance but not any more travel. I found with my 4Tec and Hummer that suspension mods helped very little. I found it more beneficial to keep the suspension stiff to maintain what little ground clearance there is and let the low CG compensate. Duratax gold shocks (the short ones) are a little longer and will give you more travel. Last edited by Grizzly4x4; 03-24-2005 at 04:58 PM. |
03-24-2005, 04:32 PM | #11 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
On my Wild Willy 2 I used touring car shock bodies with front buggy shafts to get the overall length of shock I needed. It works well but the shocks leak like a sive because of the piston & bladder issue. Looks cool with blue shocks though. When I get a Touareg I'll swap shocks.
03-24-2005, 07:06 PM | #12 |
Well, Since I can't swap shocks I will have to live with what I have. Perhaps I'll just play with spring/oil weight combos. These stock shocks are quite nice for plastic units. I plan to trim away some of the plastic on the A-arms to gain that extra .5mm of travel What other tires besides the stock Hummer treads and 'Jero/Twrag BFG's fit on these XC/CC rims? Anyone know? Trying to keep it as stock as I can yet gain something in the traction area. Locked diffs can only go so far |
03-24-2005, 07:28 PM | #13 |
Newbie Join Date: Mar 2005 Location: Jackson, Mississippi
Uh oh Toyo, I smell something... smells like you'll be cooking up some parts for the XC chassis!
03-24-2005, 08:46 PM | #14 | |
Right now I don't have much in the idea box... I haven't had enough "behind the wheel" time to really experience the rig yet. Hell, I've only ran two packs through it now. I even re-built my backyard crawling area to be a XC/CC trail system. I had a blast running it tonight, battery dumped right before my cold meds kicked in... it could have been a nasty adventure if the drugs would have kicked in sooner | |
03-24-2005, 08:59 PM | #15 | |
I really don't know until I try it. I still have not finished building the rear end yet. I have been so busy on the computer these last several days. | |
03-24-2005, 09:40 PM | #16 | |
I'd stick with the included instructions for building the shocks. Although don't install the small rubber spacer inside the shocks body/on the shock shaft. It will just be removed later. I ran the truck tonight and found that it flexes quite nicely now, much better than before. I have Losi 35wt oil and "custom" Losi white springs.... custom = cut to fit. I actually made the white Losi springs a couple mm shorter than the stock Tamiya springs. This damn thing is soo much fun to drive, especially after I revamped my backyard to allow some trials like terrain. | |
