front dig hi i may sound stupid but i still dont get how front dig works i noe it helps to steer but iono how it is setup with the disconnecting the shaft so how does it re connect? thanks |
http://media.putfile.com/dig-13 heres my setup, one axle is broke but you get the idea. also search "yellow jacket" and "revo dig" |
there is a write up in The Hustler thread http://www.rccrawler.com/forum/showt...hlight=hustler on this type of DIG SET UP ! really all dig is , it is away to unlock / open the rear drive shaft & stop the rear wheels from turning . then you turn your front wheels to the left or right and burn the tires . The rig will spin around really tight (less back ups) this helps in comps to keep your points lower . also it helps if you rig is going down a vert (acts as breaks) I hope this helps you understand. |
There is a thread stickied to the top of this TLT section. Most anything you need to know is there! Tom |
thanks also how does the shaft get back on the thing that disconnects the shaft? |
Go to orcrc.com look for the link front dig 101 |
i tried that and i made an account but i still cant log in to look at their stuff |
