stuck with bushing I got my teflon seal bearings from R2J but I can't put them on the axle because every thing is JB welded together and I can't get them out. I bought unassembled crawler on RCU( vertical Smile) and the diffs were already locked. I put the bearings in the hub and on the pinion, I guess I am stuck with the bushings on the axles. |
The shafts are glued to the differential? Wow, the person you bought that from went a little crazy... |
oh that sucks, cause now when axles get broken you gotta replace the whole thing. well better start now looking for spare parts |
The bushings are Jb welded to the axles? now the bushing will spin and wear down the plastic axles...not to mention more drag |
Nothing a hammer and vice can't fix."thumbsup" I did the bearing swap last night on the Rick scaler. The shaft had Jb ozzing out. Couple taps with a hammer is enough to break the bond. Besides what have you got to lose. I mean they break your not out anymore then you are now. |
I think I saw on here somewhere that Gasoline can dissolve JB. So you could try tossing it into a a cup full of gas overnight and see what happens... Might soften things up enough for the hammer trick to work... yep here it is... http://www.rccrawler.com/forum/showt...=gasoline+weld |
I will have to try gas, thanks |
It might be less painful just to start over. |
you could keep those inwards for back up axles. Just buy some axle casings and spare axle! |
