07-27-2007, 01:12 PM | #1 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
| Flame my new link setup please.....
Building another tuber- yes ANOTHER one. I have found it to be very stress relieving cutting and burning metal. I setup the links on this one a bit different and wanna see what everyone thinks. Pictures please.... Front setup. I know the axle is a bit overclocked (I will fix this) Rear setup. Overview. Dont worry about where I am going to place the shocks- I will change some suspension stays around to get that straight. If you see anything that looks out of whack- let me know. |
07-27-2007, 01:44 PM | #2 |
Rock Stacker Join Date: Feb 2007 Location: Cincinnati
Looks good, is this the one you got the rods for the other day? Looking forward to how it's going to come out.
07-27-2007, 02:50 PM | #3 |
07-27-2007, 02:54 PM | #4 |
Mr. Pink, It looks good to me but I a friggin Noob. The tube framing looks minimal and light this is a tuber with no extra "just for looks" extra tube. Maybe you will add more. The front and back link set ups are different, may I ask what that will produce I'm guessing a more neutral rear? I always wonder where the other gear and stuff goes Some tubers look like 1:1 crawlers but then the gear gets crammed in them and looks like an after though. I was looking at the Tim McGee's great photos posted the other day and got the desire to build a (scaler) comp rig but in my view it can't have a pile of visible gear and stuff. I think I'm partial to the ones with enough body panels that act as cover for the gear. Opinion Only Storm' |
07-27-2007, 03:02 PM | #5 | |
The base of this rig were built around the Rx and tranny.. no afterthought here- forethought makes for a smoother finish. I will post more pictures as I progress. | |
07-27-2007, 03:14 PM | #6 |
I wanna be Dave Join Date: Apr 2004 Location: SoCal
Those will never work like that. Happy? |
07-27-2007, 03:23 PM | #7 |
Bring that thing to the next TSC comp and I'll flame it reeeeeeal good.
07-27-2007, 03:32 PM | #8 |
Looking forward to those pics |
07-27-2007, 03:40 PM | #9 |
Adilynsdad too! Join Date: May 2004 Location: G ville
Heeeeeeeeeeeeeeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaay
07-27-2007, 03:57 PM | #10 |
Rock Crawler Join Date: Apr 2006 Location: pasco,Wa
well im no flamer lol like tha attachment stuff pretty standard.I would think the the upper links on the rear are to long,this should make the pinion dance around a bit when it cycles.Typically the top links are shorter than the bottom on a link setup.Easy remedy just use the tlt mounts that have 2 holes.
07-27-2007, 03:58 PM | #11 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
Looks like a Gimbal chassis plate.
07-27-2007, 04:16 PM | #12 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
I like the way you have the rears setup, but I prefer the use of long links. Longer links will help keep the axle in the center of the wheel well |
07-27-2007, 04:29 PM | #13 | |
Do you think shortening the rear upper 1/8"-1/4" would effect the setup all that much? shhh. | |
07-27-2007, 04:42 PM | #14 |
the 1/8" to 1/4" probably wouldnt make much diff.What ive learned[read]about 4 links is the top links are typically 70% length of the bottom links.Mind you im no expert on this.Im thinkin its about the geometry of it to keep the pinion around the same angle through suspension cycle.
07-27-2007, 10:05 PM | #15 | |
I do appreciate all the help I can get though!! | |
07-28-2007, 09:17 AM | #16 |
theres a real cool thread about 4 links on pirate that i read,and this is were im getting my info on the subject.Yes eepee helped me a while back on my torque twist and its been elimnated.Started out knowing nothing about link suspension i feel im fairly knowledgeable about it now.Good luck bro.
07-28-2007, 10:19 AM | #17 | |
The upper front links could be mounted inboard at the chassis. Seems their angle is fairly steep at the ball ends. You have plenty of triangulation so I don't see any harm being done mounting them inboard. And it should relieve the ball ends of some possible stress. Or use some spacers at the axle end before you put the ball ends on. Or they could be fine as they are. The rear link length could work out in your favor. As the suspension cycles it will point the yoke upward, and that will help keep it out of harms way. Always a good thing. But the range of motion is so minor, I really don't think it matters much. When everything is done, you might want to tweak the angle the uppers are at. Maybe add some spacers underneath the suspension stays on the axle. This will improve your link seperation, and get the uppers closer to parallel to the ground. And that will help with the anti squat number. The other option is to get the chassis side closer to the lower ball end. It's hard to predict what will happen honestly. | |
07-28-2007, 03:44 PM | #18 |
07-29-2007, 05:29 PM | #19 |
All done. |
07-29-2007, 05:43 PM | #20 |
Matt, we're no worse than tower, think of all the shipping I saved ya Chassis looks good, although not 9.00 to touch it good. Maybe you should bring it out on the 12th and let me see what it can do.
