Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Tamiya TLT Crawlers
Thread: ARCATT delta 1.9ine
Old 12-18-2008, 12:30 AM   #1
Default ARCATT delta 1.9ine
I had to dig pretty deep into the parts box for this one, I really didn't want to try to chop a set of axles to build a 1.9, so I started looking at some wheels...and found some 5 spokes
IRON CHEF is offline   Reply With Quote
Old 12-18-2008, 12:41 AM   #2
The Team Losi A-7801 touring car wheel has the right specs to make this work at a -5mm offset, the lhs had another set on the wall, probably for years and years, they measure up right on totally stock axles...close, but right. Holiday build on
Old 12-18-2008, 07:46 AM   #3
Is that all you've got?? Come on lets see more. That is close...........
almost 8".
gyrene is offline   Reply With Quote
Old 12-18-2008, 09:17 PM   #4
-10mm offset is all I got
The hexes for these wheels measure up to 9.4mm and are still offered. I drilled them with 13/64 bit to fit the stubs and had to file the slot to fit the fat Tamiya pin.
Old 12-18-2008, 09:50 PM   #5
damn, i tried and didnt like how it was working out so i narrowed my TLTs.
dieselfuel is offline   Reply With Quote
Old 12-19-2008, 01:36 PM   #6
We need more pictures of the wheels on the axles, thanks
JUSTGOINGSLOW is offline   Reply With Quote
Old 12-19-2008, 03:24 PM   #7
The IRON CHEF is at it again....
Don't make me post up my spy shots.
Rubbaneck is offline   Reply With Quote
Old 12-19-2008, 07:31 PM   #8
just do it
1beatjeep is offline   Reply With Quote
Old 12-20-2008, 08:17 PM   #9
Got any action shots? does it work?
I got jammed up on links but think I should have enough room to stuff everything else in 1 7/8" belly clearance and plenty of flex
Old 12-20-2008, 09:48 PM   #10
Damn, nice work..
Sparky J is offline   Reply With Quote
Old 12-20-2008, 11:42 PM   #11
how wide are you with them rims and tires at the wides point.
Old 12-21-2008, 08:52 AM   #12
Very nice build. Which car did you rob the Losi shocks from?
RivBlueNoma is offline   Reply With Quote
Old 12-21-2008, 10:27 PM   #13
Originally Posted by Sparky J View Post
Damn, nice work..
7 15/16 loaded, the wheels camber out on the axle though, it will have to fit tighter to the axle before it sees any ground & pound especially with the mini hex...make it work
Those are a real nice kick-down from a buddies Rally Weapon or Street Weapon, they have the rally springs for sure, thanks J
what's fit so far, plenty more to do...
GM SX6R
Novak BEC
Hitec 5645 MG
Mirrored Axial Tranny
35 Turn Integy
Stock TLT axles with bearings & locked
2 cell A123 Ion's
Axial chassis & custom skid
Old 12-21-2008, 10:33 PM   #14
2 cell A123 Ion's- isnt that only 6.6 volts? Id be curious to see what your run times look like.
Old 12-22-2008, 07:37 AM   #15
Damn nice build!
Old 12-22-2008, 07:43 AM   #16
hitman46mod is offline   Reply With Quote
Old 12-31-2008, 07:43 PM   #17
Finally I got a wheelie poppin 20 minutes in with 18/84 gears before the pack went soft, and put back 500mah into the pack, no problem in the voltage area. Maybe a little too perky, I am going to try a 45 turn to smooth it out a little while paint dries
Old 12-31-2008, 09:32 PM   #18
A 20 minute run time doesnt sound too bad. It would get you through any 2.2 comp around here just fine. Going for the bonus gate could be pushing it though. I see mention of paint drying, guess that means youve selected a body?
How long are those shocks from center to center? Ive got a similar build in mind but cant find the right length shocks in my parts bins.
Old 01-01-2009, 10:33 PM   #19
Originally Posted by gyrene View Post
Damn nice build!
I wound up going back to the 35 turn with a 16 pinion, 45 was too slow. TLT Max Climber body is about the only body that would fit, shocks are 70mm centered no limiters
Old 01-02-2009, 08:19 AM   #20
So....when's it coming out to play
cato is offline   Reply With Quote
