09-28-2007, 02:06 AM | #1 |
I wanna be Dave Join Date: Nov 2005 Location: Crawler practice!
| tlt comp crawler!
No money! then build with what you have! TlT axles pede tranny 45 lathe! moabs on hpi rims that have been cut! 4 inch shocks! i dont know if im going to droop or not! i will find out as i get it into a roller form! i could not find the money to buy a comp chassis! so i built one like the two i liked! the black jack from sin city and the sw2! using the stock tlt chassis |
09-28-2007, 07:30 AM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
Off to an ugly start! Can't wait to see it done!
09-29-2007, 12:57 AM | #3 |
09-29-2007, 02:06 AM | #4 |
the rear end has a little axle steer but i can fix it with shorter upper links! Here are some pics! |
09-29-2007, 03:09 PM | #5 |
shortened the upper links! but it did not help any ideas!? the links are the same front to rear! :-( |
09-29-2007, 05:01 PM | #6 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
09-29-2007, 05:54 PM | #7 | |
Edit 5 42***** well that did not help either i moved the links on the axle to the outside of the mount and the rear is almost gone but the front needs some work now! its down to a minimum so, i dont think it will hurt me to much! Last edited by smokinubyrc; 09-30-2007 at 01:28 AM. | |
09-30-2007, 01:31 AM | #8 |
alright i got the thing done! i added springs to the rear shocks to help the unloading with full droop set ups! Also got the tranny mounted, and started to mount the electronics! But i need to rip out the servo of the g wagon, my airtronics dose not like my Novak rx! Brb with pics! |
09-30-2007, 02:09 AM | #9 |
so here are some pics! What do you think of the body!? i put it on just for kicks and i sat their for like 20 mins just staring at it and saying it looks good! of course it will go under the knife if i use it! Last edited by smokinubyrc; 09-30-2007 at 02:12 AM. |
09-30-2007, 02:25 PM | #10 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Always cool to see some home built chassis. But what happened to the BMVII?
09-30-2007, 03:53 PM | #11 | |
This is just temp chassis untill i can afford a real one! i got most of the axle steer worked out! | |
09-30-2007, 06:58 PM | #12 |
im going to switch the front shocks to some buggy fronts i have, the 4 inchers have WAY to much travel! other then that the second batt is charging more testing then action shots ! |
